Grader Blade Width
/ Grader Blade Width #1
SteveInMD
Platinum Member
Brookeville, MD
TC33D
My tractor wheels are 5 feet wide. Should I get the 6 foot wide blade or the 7 foot wide model?
I'll be using it to maintain my gravel driveway - keeping a crown, etc. Also I want to use it for lawn repairs.
/ Grader Blade Width #2
I would say nothing less than 7' as you will want some stick out when the blade is angled.
Sometimes I wish I has a 7' (now have 6') behind my B2910 Kubota, which is a smaller tractor than what you have.
An 8' might even be better for you. Maybe someone with a TC33 will report their experience... /forums/images/graemlins/smile.gif
I for certain though would not go with less than 7' myself.
/ Grader Blade Width #3
Biggest single determining factor to me would be if you can rotate it 180* without hitting rear wheels. I like 'em wider than the tractor, but not too much wider. For instance, one tractor I use a blade on quite frequently is 82" wide. I use a 7' (84") blade on it. Too wide will cut down on manuverability somewhat......
/ Grader Blade Width #5
Get your steel tape measure out and angle it behind the tractor as if it were a blade and see what length will work best for you. You will want to cover your wheel tracks at all usable angles.
/ Grader Blade Width #6
All things being centered, and the blade at a 45° angle, a 7' blade will reach out 2.5' from the center, so would just cover your wheel width of 5'.
Multiply 3.5 by the sin 45, which is
3.5 (0.707) = 2.5
/ Grader Blade Width #7
Working with the blade at 45 degrees is pretty severe. Will most/all blades even allow that angle. Usually to do work which requires an angle, doesn't require that much. Also, as you've so correctly pointed out. The effective width is greatly reduced.
/ Grader Blade Width #8
Agree, with the severe 45° angle.
For a 30° angle, the 6' blade will cover the 5' wheel width.
By my calculation, the 6' it will reach out 2.6' from the center.
2.6' = 3 * cos 30° = 3 * 0.866
I agree with the comment that it is important to be able to swing the blade around 180° and not hit anything, which may dictate a length limitation.
/ Grader Blade Width #9
If you get a balde that offsets as well as angles it will be easier to rotate 180.
I went with the 7' blade. It just clears to turn around backwards. I think the 6' blade would have been too small.
Thanks.....
2008 DOOSAN G25 GENERATOR (A63569)
2008 DOOSAN G25...
John Deere 4040 Tractor (A64047)
John Deere 4040...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
2017 CHEVEROLET 550 HD LCF S/A 4X2 24FT BOX TRUCK (A59910)
2017 CHEVEROLET...
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
