Grade 8 Shear Bolt?
   / Grade 8 Shear Bolt? #1
madtowneast
Massey Ferguson 4707
Hi All,
I broke a bolt on my Case IH BS174R, specifically part # BER657199. The description is Bolt - Grade 8.8 Shear, & Nut. Is there such a thing as Grade 8 shear bolts?
Does anybody know what size the bolt is? The parts diagram says 6 are needed and I can’t figure where the other 5 are.
Thanks!
   / Grade 8 Shear Bolt? #4
Leaving this here. May help future readers.
Thanks for the replies!
Can anybody tell me the size of the bolt that I need?
   / Grade 8 Shear Bolt? #7
Many times they are 1/4 inch, BUT it depends on application, what is diameter of hole you are going to put bolt in....
Likely not 1/4 inch if it's grade 8.8! :p
   / Grade 8 Shear Bolt? #8
It might be easiest just to order the parts kit, unless you have a Case dealer near you. You probably will have it next week.
Better yet, order two; that way you can use one, and match the other up at your leisure.
   / Grade 8 Shear Bolt? #10
As point of reference:
6 mm is a little smaller than 1/4 inch
8 mm very close to 5/16 inch
10 mm is a little larger than 3/8 inch
12 mm is a little smaller than 1/2 inch
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
2025 Swict 78in Bucket Skid Steer Attachment (A53421)
2025 Swict 78in...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
