Grade 70 or 43
   / Grade 70 or 43 #1
bjess8
Bronze Member
SOUTH CENTERAL ,PA
GRAND L3130
What is the difference between Grade 70 chain and 43?can you use grade 43 for hauling?thanks
   / Grade 70 or 43 #2
As far as I know you can use the 43 or unmarked chain. You will have to work within the limits or about one size larger than a grade 70. Look at the DOT site for your state or the federal motor carrier regs.
   / Grade 70 or 43 #4
grade refers to the hard/tough-ness of the chain.
much like bolts where a grade 8 is tougher and harder to break than a grade 3.
   / Grade 70 or 43
ok thanks I just seen some grade 43 in the nothern tool book and was going to get some for hauling my Grand L 3130 and just wanted to make sure it was legal.Thanks
   / Grade 70 or 43 #6
3/8 grade 43 chain is rated at 5400# and grade 70 is 6600# not a huge difference but not a huge difference in price.
Plus the grade 70 chain has that beautiful goldish chromate finish, not only looks good but is highly corrosion resistant.
I would get the G70.
JB
   / Grade 70 or 43 #7
And the best thing about grade 70 is, you can generally go down one size in your chain. That makes it lighter! Hefting chains around gets old.. :)
And it's more resistant to rust!
   / Grade 70 or 43 #8
JB
You mean like this nice golden finish? :)
I needed a short piece of logging chain so I bought the unplated grade 43 and plated it at work. This is better then any plating you will get of the shelf. It is a zinc-nickel alloy (87/13) with chromate topcoat finish. We use it on aircraft bearings.
   / Grade 70 or 43 #10
Your original question asked if you could use grade 43 for hauling. The answer was yes but I also agree that for the minimal difference in price get the grade 70 chain. Mike posted the specs for each.
Kubota BX23 4x4 Backhoe (A51573)
Kubota BX23 4x4...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (INOPERABLE) (A52472)
2019 PETERBILT 567...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2003 International 4200 Box Truck (A51692)
2003 International...
LOT LOCATIONS (A52576)
