Jay4200
Veteran Member
- Joined
- Nov 23, 2005
- Messages
- 2,053
- Location
- Hudson/Weare, NH
- Tractor
- L4200GST w/ LA680 & BX2200D w/ LA211
Informative but not complete. You are at a big box store and choose grade 8 bolts, what nuts and washers do you get?
The nuts and washers should also be grade 8. Unless marked you will be picking up grade 2 or 5 hardware.
What if you are replacing a lower grade bolt with a higher grade, no nut to screw the bolt into, the frame is tapped?
A] You drill out the tap and use the same grade nuts.
B] You use a longer bolt to thread deeper into the blind pocket.
Washers are stamped or CUT from sheet metal. The stamping causes a slight CROWN in the washer, take advantage of the crown by placing the flat side away from the bolt head or nut.
I have found that the chine's nuts and washers much too soft for the bolts.
I don't believe that bolt grade matters. The failure mode is in the bolt (shaft). Type of nut or threaded holes are irrelevant in terms of fastener failure.
I need to pick up some grade 2 bolts - where do I find them??
JayC
