4-in-1 grab-on tools for 4-in-1 buckets
   / grab-on tools for 4-in-1 buckets #1
freedomlives
Platinum Member
Husak, Slovakia, EU
Iseki TS35F, Goldoni Special 140 with powered trailer -- Goldoni Special 128 -- Goldoni Uno for mowing -- Czech Vari system
I've seen some use of the concept, and I wonder if it would work on a small utility tractor with a front-end-loader to grab on to a bale spear for lifting round bales?
I'm looking at one seller over here (SK) who has an Iseki 27HP with the 4-in-1 bucket on the FEL. Otherwise, I imagine that switching out a 4-in-bucket for another FEL attachment must be a bit of work to deal with hydraulic hoses as well, and that I might be be better off with just a normal FEL.
Also, in that size of tractor, is there going to be any success using the 4-in-1 bucket as a box blade to make flat pathways around our farm?
   / grab-on tools for 4-in-1 buckets #3
I don't know how heavy your round bales are over there, but here they're in the 750-1400# range. I don't think a 27 HP tractor is gonna be able to pick up a 4 in 1, a bale spear, and a bale.
   / grab-on tools for 4-in-1 buckets #4
I doubt it would work.
I use a log loader trailer to pick up my haybales and how well it works is 100% dependent upon how cold it is out. If the hay bale is frozen, the log loader works pretty well. If it is not, it almost destroys the hale bale getting it onto the trailer. You would even have a worse problem trying to pinch the entire bale I would think.
Good point. I'm sure there are larger round bales here, but I wouldn't be dealing with any heavier than 300kg/650lbs, but I see now how the extra weight of the 4-in-1 bucket isn't going to help.
   / grab-on tools for 4-in-1 buckets #6
He's talking about using the 4 in 1 to pick up a bale spear which would then spear and carry the bale, not trying to grab the bale with the bucket.
2020 Deere 50G (A53317)
2020 Deere 50G...
Mohawk 12,000lb Two-Post Electric Auto Lift (A54811)
Mohawk 12,000lb...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2016 Ford Expedition SUV (A55853)
2016 Ford...
2025 Swict 66in Bucket Skid Steer Attachment (A55851)
2025 Swict 66in...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
