GR2120 wih RCK54GR deck: mower gearbox seal replacement
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #1
RickOhio
ashtabula, ohio
case 990
Anyone out there know any tricks on how to split the mower gearbox (mounted on the mower deck) so that I can replace the lower seal? I have the gearbox off, all the bolts removed holding the two together, but I can't seem to split the case. I'm afraid to beat on it for fear of screwing something up. The case halves are not sealed with a gasket but instead with sealant and the factory did a good job of sticking them together. Dealer says case must be split to replace the lower seal (which is leaking) and from what I can tell from the illustrated parts breakdown that looks to be true. Has anybody actually done this on this particular deck or one similar to it? The seal is #130 on the attached file.View attachment gearbox.bmp Thanks in advance!
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #2
Anyone out there know any tricks on how to split the mower gearbox (mounted on the mower deck) so that I can replace the lower seal? I have the gearbox off, all the bolts removed holding the two together, but I can't seem to split the case. I'm afraid to beat on it for fear of screwing something up. The case halves are not sealed with a gasket but instead with sealant and the factory did a good job of sticking them together. Dealer says case must be split to replace the lower seal (which is leaking) and from what I can tell from the illustrated parts breakdown that looks to be true. Has anybody actually done this on this particular deck or one similar to it? The seal is #130 on the attached file.View attachment 329850 Thanks in advance!
if you havn,t done gearbox yet i can help i just rebuilt ours and it really wasn't that bad
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #3
duvy, I have the gear box out, not sure how to separate the 2 halves. How did you get them apart without doing damage to the case edge?
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #4
Hello to Rick Ohio; Did you ever get your case apart? Please let me know how you did it.
C13 MOTOR (A50854)
C13 MOTOR (A50854)
MIDLAND POLY PIPE REEL TRAILER (A50854)
MIDLAND POLY PIPE...
John Deere X740 Mower (A50514)
John Deere X740...
2018 John Deere 524K-II Articulated Wheel Loader (A50322)
2018 John Deere...
TMA (A49461)
TMA (A49461)
1986 CATERPILLAR D6H HI-TRACK CRAWLER DOZER (A51242)
1986 CATERPILLAR...
