GR2120 wih RCK54GR deck: mower gearbox seal replacement
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #1
RickOhio
ashtabula, ohio
case 990
Anyone out there know any tricks on how to split the mower gearbox (mounted on the mower deck) so that I can replace the lower seal? I have the gearbox off, all the bolts removed holding the two together, but I can't seem to split the case. I'm afraid to beat on it for fear of screwing something up. The case halves are not sealed with a gasket but instead with sealant and the factory did a good job of sticking them together. Dealer says case must be split to replace the lower seal (which is leaking) and from what I can tell from the illustrated parts breakdown that looks to be true. Has anybody actually done this on this particular deck or one similar to it? The seal is #130 on the attached file.View attachment gearbox.bmp Thanks in advance!
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #2
Anyone out there know any tricks on how to split the mower gearbox (mounted on the mower deck) so that I can replace the lower seal? I have the gearbox off, all the bolts removed holding the two together, but I can't seem to split the case. I'm afraid to beat on it for fear of screwing something up. The case halves are not sealed with a gasket but instead with sealant and the factory did a good job of sticking them together. Dealer says case must be split to replace the lower seal (which is leaking) and from what I can tell from the illustrated parts breakdown that looks to be true. Has anybody actually done this on this particular deck or one similar to it? The seal is #130 on the attached file.View attachment 329850 Thanks in advance!
if you havn,t done gearbox yet i can help i just rebuilt ours and it really wasn't that bad
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #3
duvy, I have the gear box out, not sure how to separate the 2 halves. How did you get them apart without doing damage to the case edge?
   / GR2120 wih RCK54GR deck: mower gearbox seal replacement #4
Hello to Rick Ohio; Did you ever get your case apart? Please let me know how you did it.
2018 LARK UNITED MANUFACTURING S/A GUARD SHACK (A55745)
2018 LARK UNITED...
Kimball Midwest Wire Cabinet w/Wire (A59076)
Kimball Midwest...
2004 Cat 730 Articulating Off-road Dump Truck (A59213)
2004 Cat 730...
2008 International Bucket Truck (A55973)
2008 International...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
