GR2110 Deck Drift
/ GR2110 Deck Drift #1
bergenfelter
Edwards, IL
Kubota GR2110
I just took delivery on a new GR2110. One thing I have noticed is that if I raise the deck to the full up position, even with the engine left running, the deck drifts to the full down position after 5-10 minutes. Is this normal? Something that can be adjusted? Any help appreciated. Thanks.
/ GR2110 Deck Drift #2
Your valve spool night have some leakage, or it could be the lift cyl seals leaking.
Is the valve spool going back to neutral.
Does the deck drift down over night?
/ GR2110 Deck Drift
Yes the spool goes back to neutral, and it will drift down within 10 minutes. Really hate to send this back to the dealer - has less than 2 hours on it, brand new...
/ GR2110 Deck Drift #4
Make them repair or just return the machine for one that will meet your satisfaction.
That kind of drift down would ruin your lawn if you didn't know about the drift.
2021 KENWORTH T680 6X4 T/A  SLEEPER TRUCK TRACTOR (A59912)
2021 KENWORTH T680...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2014 Ford F-150 4x4 Ext Cab Pickup Truck (A64194)
2014 Ford F-150...
2021 Case 200 Magnum (A64119)
2021 Case 200...
2009 Ford F-450 Liftmoore 5000 2 Ton Crane Service Truck (A61573)
2009 Ford F-450...
