GPS for running fencelines
   / GPS for running fencelines #1
wolfgreyt
NH 4060
I have to run new fence lines thru very thick woods and along several grown over pastures. Wondering if anyone has used and had any success using handheld GPS units . I already have a survey however markers on the actual land are long since gone.
   / GPS for running fencelines #2
I got one this fall before hunting season and was surprised at how much it could do_One slick feature is it let's you mark waypoints in the woods and then will import them into Google Earth. Also, my county has an online taxmap which shows arial views with the property lines drawn in. Not survey accurate but close enough for most needs.
   / GPS for running fencelines #3
it can be done, but the accuracy of consumer hand helds is lacking compared to commercial units.. For something like a fence, where you could be putting something permanent on a neighbors land, id look for something a little more precise.
The lack of accuracy of consumer units is extra bad when their is a overhead canopy of trees to try and get signal through.
Just something to think about, because you'll be responsible if you cross onto a neighbors property.
If this is within your own property (ie not directly next to a neighbour) then using a consumer unit would be perfectly fine.
   / GPS for running fencelines #4
That is true. Mine has an accuracy reading on it. Best I've seen is 5-10', sometimes it's 50 or 60. If you are building a fence you will be doing some clearing. I've had good luck using flags tied to whatever was available and line of sight, starting at the first two stakes on the line. That's providing you can find the first two and the line is a straight one.
Thanks for the input, I did the ribbon tying thing on trees with a very long tape measure and the survey. Its enough for the start , I hear ya on the property line thing, I don't want any issues.I have not tried any of the newer handhelds so I was wondering about the accuracy. Actually found some very old rotted fence posts but will have to wait for spring to verify everything they may be unrelated to the property line..Then I'll hammer in some t-bar markers. The plan is to run a road along the line for a horse driving trail. Some of the land is a forested cedar swamp thats hard going in spring and summer .
   / GPS for running fencelines #6
I use GPS all the time at work. Form the handheld WAAS corrected Garmin units to commercial grade trimble units. From our experience you typically can get 5-10' accuracy positional (not elevation) accuracy with a handheld unit with clear view of the sky. This is based off of countless comparisons between hand held units and commercial grade RTK units.
This level of accuracy is no where near good enough for building a fence. If your neighboor is in agreement you might could use the handheld to mark where the fence goes and then clear it out so you can use another method of actually positioning the fence.
Thanks for the info ! For now I think we are just going to clear a swath thru the bush , a joint effort between my current neighbour and me. I will use it as a driving trail for horses. We have alot of hemlock and cedar to move.The fence will have to wait until an accurate line can be re-confirmed. I was considering one of the Garmin handheld units, any opinions on them or a particular model?
2009 New Holland 4060 w/loader/4wd
   / GPS for running fencelines #8
How sure are you that the corner marker pins aren't there? Have you checked with a metal detector?
   / GPS for running fencelines #9
The newer high sensitivity units keep accuracy even under vegetation cover.
If you are in WAAS (Wide area augmentation system) area the accuracy can be up to 3ft. You can take several measurements and then take the average. To verify it take measurement of known location.
If you are going to buy GPS get high sensitivity WAAS capable one.
   / GPS for running fencelines #10
you need to pay attention to the position accuracy. I dont care if it thinks your within 3' of the point you wanted, if the position accuracy is currently saying +-15' guess what, that "within 3'" number is useless.
but putting aside the issues of accuracy associated with any hand held GPS
theres also the issue of generating the points you need to set the line. finding corners are one thing, but setting points along the way is entirely different. you need to know for certain what your end pts are, then useing those coordinates, using math generate the new pts along the way.
doable but not easy.
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2019 Allmand Bros Maxi-Lite II 15kW S/A Towable Light (A52377)
2019 Allmand Bros...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
2000 GROVE RT640E MOBILE CRANE (A51406)
2000 GROVE RT640E...
2018 JCBTruss Jib Telescopic Hyrualic Boom (A53421)
2018 JCBTruss Jib...
