Code54
Elite Member
- Joined
- Aug 20, 2005
- Messages
- 4,309
- Location
- Putnam Co. West Virginia
- Tractor
- Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
I have a question regarding surveying and how they write the plat maps. The Plat map of my property has some sort of longitude and latitude markings (I think they are at least) but I can not line them up with my GPS. I am guessing this is a different datum or way of expressing the position of property lines. The pins are all in on the property but several places it is very hard to see them (due to contour of the land) and I figure if I could use the map marking I could easily follow the lines. An example of the marking are:
N 18* 37’00’ E
S 66*39’12’ W
The * is supposed to be a degree symbol
Any idea how I can set my GPS so the readings would be the same as this map? Is there a certain Datum surveyors use and is it even called a datum?
Thank you
N 18* 37’00’ E
S 66*39’12’ W
Thank you
