gotta be a cheaper way
   / gotta be a cheaper way #1
LOOPHOLE
Horry County,SC
140 Farmall w/belly mower NH 1925 FEL/BH
took a swing cy from BH to local NH dealer for seal repair
said I needed to replace rod/had scar on it
MERCY !! seal kit,rod and labor over $550
Bet the cyl new would be cheaper/ ya think?
NH 757c model
There has to be a cheaper way / where did I go wrong ???
   / gotta be a cheaper way #2
You can look for a good used, or get the parts separately and do it yourself..
   / gotta be a cheaper way #3
Take it to a hydraulic repair shop. That is way too high.
   / gotta be a cheaper way #4
Get the seal kit, does not have to be a NH kit. After market kits are available. Depending on how bad the scar is, but I would probably just use some 400 grit wet dry sand paper and sand the rod smooth. Obviously only if the scratch is superficial. Maybe post a picture of the scar. I would think that a seal kit would be less than $50.
   / gotta be a cheaper way #5
The scar can be TIG welded with stainless rod
   / gotta be a cheaper way #6
yea,I know-pitchers on the subject is worth $ / I just don't have a way to post them right now- I guess now I should have told service mgr to install seal on old rod and lets see how long it last/ after all it was a swing cyl - not bucket tilt ,etc
I blew it out pulling on a stump/scar or pit on rod looks to be not a fresh wound either
OH WELL-LIVE AND LEARN I GUESS
Based on the number of threads I see with leaking seals on cylinders,the repair shops should have plenty of work
   / gotta be a cheaper way #9
Yep, nh parts ain't cheap. Go to messicks and price the whole cylinder. It would give you a heart attack.
My 5500, for kicks , I priced some of the cylinders. $1800-$2500 depending on what one.
Hydraulic shops are a lot cheaper. Old likely could have made you a new rod, and rebuilt with new seals for less than half that quote
   / gotta be a cheaper way #10
Usually I only worry about scratches in the rod if you can catch a fingernail in it and I try to buff them out with the thought being if it's smooth it won't tear up the seals
PREDATOR TRI-FUEL 13000 GAS PORTABLE GENERATOR (A54757)
PREDATOR TRI-FUEL...
Utility Trailer (A52377)
Utility Trailer...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2013 BMW 528i (A55758)
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2015 Peterbilt 320...
