gotta be a cheaper way
   / gotta be a cheaper way #1
LOOPHOLE
Horry County,SC
140 Farmall w/belly mower NH 1925 FEL/BH
took a swing cy from BH to local NH dealer for seal repair
said I needed to replace rod/had scar on it
MERCY !! seal kit,rod and labor over $550
Bet the cyl new would be cheaper/ ya think?
NH 757c model
There has to be a cheaper way / where did I go wrong ???
   / gotta be a cheaper way #2
You can look for a good used, or get the parts separately and do it yourself..
   / gotta be a cheaper way #3
Take it to a hydraulic repair shop. That is way too high.
   / gotta be a cheaper way #4
Get the seal kit, does not have to be a NH kit. After market kits are available. Depending on how bad the scar is, but I would probably just use some 400 grit wet dry sand paper and sand the rod smooth. Obviously only if the scratch is superficial. Maybe post a picture of the scar. I would think that a seal kit would be less than $50.
   / gotta be a cheaper way #5
The scar can be TIG welded with stainless rod
   / gotta be a cheaper way #6
yea,I know-pitchers on the subject is worth $ / I just don't have a way to post them right now- I guess now I should have told service mgr to install seal on old rod and lets see how long it last/ after all it was a swing cyl - not bucket tilt ,etc
I blew it out pulling on a stump/scar or pit on rod looks to be not a fresh wound either
OH WELL-LIVE AND LEARN I GUESS
Based on the number of threads I see with leaking seals on cylinders,the repair shops should have plenty of work
   / gotta be a cheaper way #9
Yep, nh parts ain't cheap. Go to messicks and price the whole cylinder. It would give you a heart attack.
My 5500, for kicks , I priced some of the cylinders. $1800-$2500 depending on what one.
Hydraulic shops are a lot cheaper. Old likely could have made you a new rod, and rebuilt with new seals for less than half that quote
   / gotta be a cheaper way #10
Usually I only worry about scratches in the rod if you can catch a fingernail in it and I try to buff them out with the thought being if it's smooth it won't tear up the seals
2017 FREIGHTLINER M2106 TELESCOPIC BUCKET TRUCK (A51406)
2017 FREIGHTLINER...
2016 Kia Optima Sedan (A48082)
2016 Kia Optima...
2014 Chevrolet Equinox SUV (A53424)
2014 Chevrolet...
2025 GIYI GY-ZWB Hydraulic Backhoe Arm with Tooth Bucket Mini Skid Steer Attachment (A55787)
2025 GIYI GY-ZWB...
2011 Ford Explorer SUV (A55758)
2011 Ford Explorer...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
