Got wind turbine blades? Build bridges.
   / Got wind turbine blades? Build bridges. #31
So you're saying it's just like farming and the oil and gas industry then. Won't argue that one.
Oil & gas are also subsidized but not even close to the same extent. I've heard that number before but I'm not confident enough of my memory to repeat it. 👍
   / Got wind turbine blades? Build bridges. #32
I went to the funeral of a pilot friend a couple of weeks ago, and it was the first time I have ever seen a wooden casket. It was white with wooden hand rails and some decorative art, very tasteful.
I don't know if price was a factor or that was his wish.
Family and friends built the coffin and vault for the last funeral I went to 2-3 years ago. The "vault" was built in my shop.
In Maine it's legal to be buried on your property, this one was on his home place.
Pretty nice "home grown" funeral.
   / Got wind turbine blades? Build bridges. #33
knowing what happens to a corpse in a sealed box.... all the liquids. Blech.
I believe that the liquids are removed.
I don't care what they do to me when I'm gone. It's not like I'll be needing this body again. Otherwise I might have taken better care of it.
   / Got wind turbine blades? Build bridges. #34
If you're embalmed, the body fluids are replaced with other fluids.
In Indiana, there's no requirement for the removal of body fluids, or embalming.
Refrigeration can be used in place of embalming.
Body fluids aren't removed for cremation.
Have you ever been a pall bearer at a funeral? The corpse is heavy. About 60% of the body is water.
   / Got wind turbine blades? Build bridges. #35
Without reading the whole thread I read elsewhere they can be ground up and added to asphalt as a filler for making highways.
   / Got wind turbine blades? Build bridges. #36
   / Got wind turbine blades? Build bridges. #37
Government regulations should state that if the manufacturer cann,t come up with a safe way to re-cycle the product they make, then it should not be allowed, by law, to manufacture them.
Government wanted them to begin with...
   / Got wind turbine blades? Build bridges. #38
Jtp...Do you have a road in mind? 5030 has an idea.
   / Got wind turbine blades? Build bridges. #40
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
(APPROX 15) 2" X 6" X 20'- 3/8" THICK METAL TUBING (A54757)
(APPROX 15) 2" X...
MISC PALLET OF DRIVELINE PARTS (A55745)
MISC PALLET OF...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A56138)
2020 INTERNATIONAL...
2018 MITSUBISHI OUTLANDER SPORT (A55745)
2018 MITSUBISHI...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
