Got to see the BX 22 today
   / Got to see the BX 22 today #1
dcollie
Fairfax Station, VA
Kubota BX22
Well, my BX22 is on order, but probably won't get here for a bit, so today they had a tractor show at the Kubota dealership in Fredricksburg, VA and I went down there as a knew they'd have a borrowed BX22 to look at.
Oh boy....WHAT A TRACTOR! This one is really, really nice. I was lucky enough to actually have the Kubota Zone Rep explain and show all the features to me. The backhoe drops off in minutes (though you have to install all components of the class 1 hitch if you want to run an implement on the rear) and there is plenty of room at the backhoe station even for us larger boyz (5'11" 225 lb) to climb up there. The seat has a very slick pivoting mechanism to not only turn it around, but lift it up in it's frame a few inches.
The Rep told me he was allocated a total of 5 BX22's for all of his zone (16 dealers) and has 12 more coming in next month, and 20 the month after that.
Some suggestions he made to me: Get the 10" bucket instead of the 12" for the backhoe. If you are digging a ditch, that's less of a cut in the earth to have to backfill, and it will be easier to dig out tree stumps with the 10"er. He told me the turf tires should be fine unless working in mud and will be much easier on the yard in a mower configuration. Also, he does not think that filling the rears for added weight will be necessary as long as the backhoe is attached when using the FEL.
He pointed out several durability features of the backhoe to me (which didn't mean a lot, what I know about backhoes could fit into a thimble), such as cast structures (vs. stamped) and a hydraulic limited instead of chains.
The grill guard that is standard on this model is quite nice and has a 'BX22' logo on it.
I took some digital photos of it, will post when I'm on my home computer where my camera drivers are.
-Duane C.
   / Got to see the BX 22 today #2
dcollie,
Where are you located? Were did you order the BX22? From Byrd?
I'm located near Manassas. It's a shame you aren't lookin for something bigger. I have my used L3410 for sale.
   / Got to see the BX 22 today #3
Yes, I did order from Byrd in Manassas. I'm in nearby Farifax Station and the BX size is perfect for me an 'estate' compact tractor and move up from a Cub Cadet 2000 series garden tractor.
   / Got to see the BX 22 today #4
They are a sweet machine for sure,and I hope your new BX deliver A.S.A.P.
The only thing I didn't like about the BX22..I don't own one. /w3tcompact/icons/sad.gif
   / Got to see the BX 22 today #5
WOW. First time I've seen a BX22. Right now I have a Yanmar 1702d. The 48" KingKutter just isn't cutting it and I really want a FEL and BH. I'm located in VA as well (Dinwiddie). What comes standard on the BX22. I'm assuming FEL, BH, and a midmount mower? I guess I could always use the KingKutter if I need to go down the trail and cut. Thanks guys!
   / Got to see the BX 22 today #6
Amazing what the addition of a backhoe does for a tractors prestige. J
   / Got to see the BX 22 today #7
The MMM is an add for the BX22. FEL and BH are standard. The 3pt parts come in a box. Ready to install upon removal of the BH. C
   / Got to see the BX 22 today #8
dcollie,
Way to go. It is a very well designed/ built machine. I looked at a lot of compact tractors prior to buying the BX22
What kind of base price is the BX22 going for back there. I'm in Calif and just put down $15,600 for mine see (delivery next week).
   / Got to see the BX 22 today #9
I just got home from the "Spiderman" movie and had a chance to run by the local dealer. We came to a price of $16,500 with the FEL, BH, and 60" MMM. I went in saying I knew where I could get it for $16,500 but I rather deal with a local. He proceeded to tell me that was a pretty good discount on the tractor and he could do that price for me. Then he showed me his shop and told me to jump on any machine I wanted and try it out. He seems like a decent dealer to me.
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2018 Ford F-250 4x4 Crew Cab Gooseneck Service Truck (A51692)
2018 Ford F-250...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
UNUSED Black Outdoor Patio Fabric Screen (A53117)
UNUSED Black...
