Buying Advice Got the itch for a new mower
   / Got the itch for a new mower #1
hillslider
MN
Kubota L3130 JD X750 and X350
So I currently mow with a JD X700. Been a great mower for the last ten years. Only thing I’ve done to it is front tires and I installed the suspension seat. So....I’ve been wanting a new mower. Was pretty much set on the JD X750. But today stopped at a local Kubota dealer.....I already own an L3130.....and looked at a BX2380. I only need a mower but man the little BX is 100 bucks cheaper than the X750. Does anyone use the BX just to mow? Any issues with that big of a tractor constantly on your lawn?
   / Got the itch for a new mower #2
I mow with a BX2380, it works great and isn't tough on my lawn. It has R4 tires, liquid ballast in the rear tires and rear wheel weights. The lawn is about 2.5 acres with a ditch slope to mow, the 4wd works great on the slope.
   / Got the itch for a new mower #3
I suppose it has a lot to do with the type of grounds you are mowing but have you looked at zero turn mowers? I have a Kubota B2650 for snow and yard work but I mow with a Kubota zero turn.
   / Got the itch for a new mower #4
I don’t know why you’d spend that kind of money on a lawnmower and not get a commercial ZTR.
   / Got the itch for a new mower #5
Agreed. I love my Kubota Z-turn. As long as you don't have too steep of slope that you have to traverse, a Z turn is the way to IMO.
P.S. A strange time to get the itch for a new mower with winter and all but better be early than late. :laughing:
   / Got the itch for a new mower #7
I've mown my lawn with a B1750HST since 1993. Works great.
The only other thing that I have used the 1750 for is snow plowing.
Can't use a ZT due to steep hills.
SDT
   / Got the itch for a new mower #8
Bingo.
ZTs will not hold steep slopes and damage turf on not so steep slopes.
SDT
   / Got the itch for a new mower #9
Bingo.
SDT
I’ll run against you with my Grasshopper any time. Low end ZTRs might suck on slopes but commercial ones will handle them like a boss. I’ve mowed 30 degree measured slopes and probably gone steeper. The wheel base is close to 60” wide and all the weight is low it’s really stable. With bar tires on the back traction is good. I test drove a Ferris 2100 before I bought my Grasshopper. It did a better job on hills than my Grasshopper but not as good as my Grasshopper.
   / Got the itch for a new mower #10
It’s been nearly 60 degrease here for a week and the grass is starting to green up a little. I thought I was going to have to move the lawnmower repairs to the front burner but I think winter is coming back next week.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A53472)
2017 Yale GLC050VX...
2019 Ford F-450 Service Utility Truck, VIN # 1FDUF4HT9KDA04609 (A51572)
2019 Ford F-450...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2017 Club Car Carryall 550 Electric Utility Cart (A51691)
2017 Club Car...
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
