Got that pesky bamboo out at last.
   / Got that pesky bamboo out at last. #1
Alien
Elite Member
Grantham, South East Queensland
Kioti CK30 HST
Got a bit tricky when I tore a valve off a front wheel. Too bad about the lawn.
   / Got that pesky bamboo out at last. #2
Glad you were able to get stump out :thumbsup: sure were little hard on tractor...not good for front hub seals believe me. ;)
Yes Thomas. I do need a bigger tractor. LOL Gotta use what I have for now.
   / Got that pesky bamboo out at last. #4
That was painful to watch.
Next time consider some ballast on the 3 point end. Better yet a chain around the stump and pull with the drawbar. Put a little distance between the stump and tractor with a load in the loader bucket.
   / Got that pesky bamboo out at last. #5
Wow please don't ask to borrow my tractor..........:) ,But at least you got it out........
   / Got that pesky bamboo out at last. #6
Wow, several things on the DO NOT DO LIST. No ballast on the rear which would have been very helpful. Bouncing the tractor while perched on the front wheels, bad for front axles, FEL and tractor frame. Letting the load shift back onto the tractor, very dangerous.
Glad you got it out but it would have been much easier to just put on an implement on the back, hook a chain around the clump and pull it out using the drawbar.
You were very lucky not to have damaged your hood, turned over the tractor or worse.
   / Got that pesky bamboo out at last. #7
Definitely a “not how to use a tractor” video. Tractors are made for pulling, not digging from a FEL. Anyway just hope the machine keeps working for you!
Also noticed your ROPS is down...not good at all.
   / Got that pesky bamboo out at last. #8
Nice work Mate! :thumbsup:
btw, I noticed that your tractor is not a Kubota that it didn't break. :drink:
Yes I know there were a few things I should NOT have done. I took off my flail mower so that I could move around better. The weight would have been useful. Larger tractor down the line when the other farm sells.
ROPS? yes I agree. I took it off so I could get it in my barn and it will be going back on when I build my new barn.
Not arguing with any of you. I know I was very naughty.
@ the old grind. LOL It is a tough little machine but I thought Kubota were OK.
It was getting late when I finished.
   / Got that pesky bamboo out at last. #10
I'm surprised you didn't permanently damage that right front tire after you spun it on the rim and broke the bead seal.
When I remove giant reed grass (very similar to bamboo), and I can't pry it out with my bucket or forks, I dig out each side then then throw a chain around the roots and pull. It usually just tears right under the roots and pops out the other side, but that at least gets them severed all the way through and I can then roll the stump out of the hole.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
2023 Polaris Sportsman 570 AWD ATV (A50324)
2023 Polaris...
Hydraulic Lift Platform (A50121)
Hydraulic Lift...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
