Got my wicked tooth bar installed
   / Got my wicked tooth bar installed #1
bdog
Elite Member
Texas
John Deere 6130M
Haven’t had chance to test it out but it looks like it will do the trick. The fit was perfect. I took the measurements per their instructions and it fit like a glove. I didn’t have to beat it in with a hammer but the width was so perfect it required a decent shove to get it between the bucket edges. Install was super easy. Two bolts on each side and nine across the front. You have to drill 3/4” holes for the sides and 5/8” for the front. You definitely don’t want to bump into this thing It is sharp.
No it is made by Everything Attachments.
   / Got my wicked tooth bar installed #3
Nice post up some photos so we can see it in action.
   / Got my wicked tooth bar installed #4
I got my 72" EA blade about 3 months ago.
Same fitment experience as you indicate - tight, perfect, like a glove.
It will dig...
Very satisfied with it, just like my 3 other EA implements!
   / Got my wicked tooth bar installed #5
Why does this bar need nine bolts across the front edge? Most other such bars only have the two bolts on the side of the bucket. Seems unnecessary to me!
Cheers,
Mike
   / Got my wicked tooth bar installed #6
EA guidance is although they include them, they are not mandatory.
My take on it was why not take the extra 30 minutes and add them for strength...for the bucket.
   / Got my wicked tooth bar installed #7
looks 'wicked' !
Wish I knew about those before I bought a flat factory cutting edge for mine. I do like that mine is reversible and uses the factory holes, but I'm sure that wicked one digs into piles and shrubs much better.
   / Got my wicked tooth bar installed #8
That is Wicked but the BXpanded Piranha Tooth Bar is much cheaper. I've had mine for about 6 years and happy with it. It used to be scary sharp but has worn a little with use.
It does NOT come drilled with the holes but they are not needed.
   / Got my wicked tooth bar installed #9
Two to mount, the rest on the lip are for a more permanent mount. I also only did the two on the side of the bucket with zero issues.
202473 (A54757)
202473 (A54757)
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
Grey Metal Roof Panels (A55758)
Grey Metal Roof...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
2019 Ford F-350 4x4 9FT Flatbed Truck (A56858)
2019 Ford F-350...
Deere 350G LC (A53317)
