Got my sawmill up and running!!! TIME TO MILL!!!
   / Got my sawmill up and running!!! TIME TO MILL!!!
Air dried lumber is perfectly suitable for use providing it’s correctly dried. It does take awhile.
For interior use? Maybe in New Mexico where there in low humidity and fewer moisture loving bugs. And that is still a maybe.
   / Got my sawmill up and running!!! TIME TO MILL!!! #22
Bark beetles are found in the cambium area between the wood and bark and are stripped off when the log is debarked. Wood borers are typically found in recently dead trees, not green trees that are felled, debarked, and milled. The process of drying wood makes them not suitable hosts for insects. Green wood has been successfully air dried for centuries in humid climates when the boards are properly stickered and kept under roof with good air circulation.
   / Got my sawmill up and running!!! TIME TO MILL!!! #23
And some more references:
And a good USDA book that addresses everything:
Well I am not taking any chances, nor do I have the time to air dry this round, so I will have it kiln dried. I hope to have a solar kiln built by the summer and I will no longer have to transport it to the kiln.
   / Got my sawmill up and running!!! TIME TO MILL!!! #25
To paraphrase another TBN member's signature;
When you have a sawmill, everything looks like a board.
   / Got my sawmill up and running!!! TIME TO MILL!!! #26
I only have a chainsaw sawmill, but it's done quite a few slabs for benches and tables.
Good luck with that mill, looks great!
   / Got my sawmill up and running!!! TIME TO MILL!!! #27
What fun you have ahead of you! While we never owned a mill my FIL and I have cut some trees and had the sawyer come out and cut what we dropped. The biggest was about 25" dia they sure get heavy fast, luckily the kioti made that part easy. While it was mostly pine we did get some cedar logs cut up too. Air dried them all. The pine ended up on the outside of a tractor shelter that got detroyed about a month later during a wind shear storm. But the cedar made it to the house. It's in my den (FIL old house, built in 1940). I almost always look at it and think of him, his perseverance and that the wood came from this farm.
BIL had an almost 30" black walnut tree blown over. I cut it into logs and took to the sawyer. He made some beautiful slabs that I put in a cement floor shed to dry. My plan is to use that one day to make "stuff". I did turn my first bowl down of black walnut and cedar. That turned out real nice I think. Pics below for that.
This is a picture of the cedar boards on my den wall.
What wonderful memories!! That is some amazing work you have there, gorgeous!! Some day when I have more time I would LOVE to get into woodturning. I really appreciate how woodturning produces a product that is the perfect combination of beauty and function. So cool!!
   / Got my sawmill up and running!!! TIME TO MILL!!! #29
I'm in the same position as Eddie -post #14. And brother - do I ever have the pine trees. All the way up to 40" on the butt.
My 80 acres was part of a 160 acre homestead. 160 acres - divided between two brothers. The old homesteader here - John Martin - built four buildings out of rough sawn pine. Two of the four were still standing when we move onto the property y 1982.
One day a man appeared in his pickup. It was time for my mid-morning break from house construction. So I climbed down and we talked.
He wanted to purchase all the old rough sawn lumber from the two remaining buildings. He was going to clean it all up - use it in the den on one of the UBER expensive homes he was constructing in Spokane. We struck a deal and that is where the two old homestead buildings went.
   / Got my sawmill up and running!!! TIME TO MILL!!! #30
Glad you allowed them to recycle it.
My FIL had taken down many an old house and reclaimed the wood. I was just grunt labor he built barns/shelters that have been standing an additional 40-45 years.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Chevrolet Silverado High Country (A56436)
2019 Chevrolet...
large capacity skid steer bucket (A56857)
large capacity...
Parker 6255 Gravity Wagon (A59814)
Parker 6255...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
