Got my accumulator Warranty kit (1430 to 1850 owners)
   / Got my accumulator Warranty kit (1430 to 1850 owners) #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, this may be the biggest ripoff from PT yet.
2 elbow fittings 1/4" npt male to 1/4 pipe male $5.80
36" hose 1/4" npt Female to 1/2" (I think) male pipe $ 18.85
No instructions other than what Terry said... Which was remove the plug on top of the accumlator, put in the elbow. Drill a hole in your tank and tap this bad boy in.
Now, why in the heck we are not just putting in a T connector on one of the small return lines is a mystery to me, and the way I am going to g about this.... I am not going to drill in to my tank for sure....
   / Got my accumulator Warranty kit (1430 to 1850 owners) #2
Drill a hole in your hyd tank? Does it say in the instructions how to stop the metal shards from entering the tank?
   / Got my accumulator Warranty kit (1430 to 1850 owners) #3
Could add a right angle hose fitting to the cover - drill the cover remotely, install it and then run a hose to it?
Ken
Nope, then you would have a hose holding your lid up...
   / Got my accumulator Warranty kit (1430 to 1850 owners) #5
Carl.
If your tank has a bolt on hydraulic filler plate, you could remove the plate and using a magnet , drill into the tank for the return hose. You could also tee into a return line, and accomplish what you want to do.
So just an update.
I went and bought a T Fitting and had them remake the hose with both JIC female ends.. I planned to tap into the return line of one of the hoses at the tank.
Well... Darnit. The friggin hose was cut about 4 inches shorter than the original... And it is a 20 mile drive to get the hose replaced....... So I opted to hook it up at my draft control overflow.... This is located alongside the fuel tank on the 1850... Got it all plumbed and I guess it is working. We will see... I put the bucket up high and stopped the tractor...
Carl
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
28013 (A50322)
28013 (A50322)
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
