Got moisture?
/ Got moisture? #1
Southernspeed
Central Virginia
Massey Furgeson 2850M
So I cut and baled my first ever hay this week! All went well and the weather was better than expected. I baled on Thursday although now, on Friday evening, I wish I'd left it 'til today.
When I baled, the windrows were nice and crunchy. The grass would break easily and felt good to my inexperienced mind! Now it's in 4x4 bales I got paranoid about moisture levels so ran out today and bought a probe type moisture tester. Probing several places around the bales I'm getting readings of 17% up to 38% ! Surely this is way too wet but why such a range of readings? Are these testers reliable?
I was feeling very pleased with myself doing my first hay but now I'm disappointed and wondering what to do with a load of ,possibly, junk hay.
Is there a better way to test moisture?
How bad is moisture? (mixed grasses)
Should I leave these outside, uncovered for a month as I've read??
Any wisdom greatly received as always.
/ Got moisture? #2
Moisture in baled hay shortly after it's baled always rises. Years ago when I had first purchased a probe type moisture tester I had a similar experience to your experience. If I remember correctly hay I tested the day of baling was in the mid teens moisture % but next day was in the mid to high 20%moisure content. Your 38% moisture probe location is probably just an isolated wet spot. What % of moisture % tests in mid 20's probes vs over 30%??
/ Got moisture?
It’s very random. I’m checking each bale in several spots and depths. In the ‘teens is the exception, maybe two thirds of readings in the 20s, rest in the 30s.
I guess the warmer they get inside , the more humidity they’ll have?
Temps in bales yesterday evening were mid 90s. Some bales in my barn, bought in last year were around 80 degrees and 14-17% humidity.
This tester ( agratronix DHT-1 ) says that used on 100% mixed grass as opposed to alfalfa will read around 5 points higher on a 20% bale. Not exactly a precise instrument!!
/ Got moisture? #4
It's going to go bad. Whatever you decide, remove any broken open bales from the barn. The problem is that even though the hay seemed crunchy, ground moisture gets pumped into them unless you pick it up immediately. Plus, that's what the conditioner does on a mower-conditioner. It cracks the stems of legume plants to free the internal moisture content. Raking is a talent to be learned, too. You want it flipped ground side to the top when the top is dry. Roping the windrows also inhibits drying. I was told long ago that you should be able to hear the hay make crunchy sounds when being picked up by the baler. (presuming that you don't have a cab or the radio is on too loud).
Wet/damp, or moisture over 20% is harder on the baler, too. It tends to tear at the plunger instead of shearing.
But, congratulations on making your own! I remember tossing my very first bale into my horse pasture and enjoying watching the critters tear it apart. If you are planning to sell any of it, don't produce moldy hay. 1 bad load will take 10 customers away. A good load may bring you 10 more ! BTW: Some 2 year old small square bales of grass & weeds I produced sold at auction last week for $7.45 at the local auction, minus 10% for the auctioneer !
/ Got moisture? #5
Gert yourself a quality moisture tester like a Delmhorst which is what I use. They aint cheap by a long shot and I have slipper shoes in my round bailer that constantly monitor the RM of the hay I'm bailing plus I'll sample windrows prior to bailing using a 5 gallon bucket and the Delmhorst hay moisture sampler. Been doing it so long I can tell by the chaff cloud coming off the bailer about how dry the forage is. That comes with experience.
Nice thing about the Delmhorst is, it also works as a wood moisture meter (with the proper probe).
/ Got moisture? #6
10% for the auctioneer.... I should have been an auctioneer. better returns than anything I ever did in my life other than stock market.
/ Got moisture? #7
Some years back when there was a hay shortage here (before I got into the forage growing business), I was hitting the local auctions with one one of the company tractors and their Talbert single drop trailer and of course I had my Delmhorst with me. I'd go around stabbing round bales with the moisture threshold alarm set at 23% and it made liars out of a lot of the people selling what was supposedly 'good' round bales. Like the 'Pied Piper', I'd get a crowd following me as I probed hay bales. The auctioneers weren't happy with me but I cared less. I was there to buy hay, not moldy crap.
/ Got moisture? #8
did you twist test the hay before baling?
/ Got moisture?
Yes, nearly all of it broke with a few exceptions that were thicker stems from shadier areas.
Checked moisture again last night and it generally seemed lower slightly, temps in the bales were a few degrees lower too.
/ Got moisture? #11
If temperature in bales is steady to lowering I think your hay will be fine.
/ Got moisture? #12
Neither of the 3 Delmhorst moisture testers that I owned lasted very long & they sure didn't have capability to measure hay temperature
/ Got moisture? #13
Interesting. Delmhorst has no issue warranting their test instruments. Mine is over 15 years old and other that not keeping a 9 volt battery in it when not in use, I've had no issues with it ever. Mine won't measure hay temperature either but my long probe analog thermometer will.
You must be pretty flush as Delmhorst's aren't a cheap date.
/ Got moisture? #14
My neighbor gave me one that he did use. 1st one purchased lasted several yrs then quite operating. I sent it back for repair & it lasted a few yrs & stopped operating so I purchased a new tester & a few yrs later it quit operating so I just bale utilizing my 35 yrs of baling experience.
/ Got moisture? #15
Congratulations on your first crop!
If it twist tested easy in the field you will likely be fine. I've rushed some hay with rain coming and 4x4 baled some that wasn't quite ready. Bales kept and cows ate it.
If you found a really damp one it could have been a green slug in the field. When I did more square bales it was easy to find the bale that had the bit of hay that was in the shade or the tedder missed.
I've never owned a moisture tester. I've done the "microwave" method for testing moisture, it requires nothing but a good digital kitchen scale & microwave.
I wrap most of my bales now, less headaches with weather and drying.
If wrapping:
20-40% is haylage
40-60% is round bale silage.
/ Got moisture? #16
I will add if you are worried leave the bales in the field for a bit or place the bales in a wide open space that gets lots of wind and sun. Space the bales out so all sides can breathe.
/ Got moisture? #17
Only time I actually use mine is monitoring the forage input to the round bailer via the slipper shoes. You have a different climate than we do up here however,
