Got blasted in the Sierra with lots of snow....
   / Got blasted in the Sierra with lots of snow.... #11
With the shear pin removed do the feed augers turn freely?
Does your PTO start and stop abruptly? If yes this can also fatigue sheer pins.
if the bolts you are using are fully threaded or there's sideways force on threads (because the shank is too short), it will break with less force than the correct shank length shear bolt that's only threaded where the nut goes.
Good information to know, thanks everyone for a lesson on shear bolts.
   / Got blasted in the Sierra with lots of snow.... #13
This has got me thinking. I made mounts and a front PTO for my Kubota M7060. I sized all the drive components for the 64 PTO HP of the 7060. That called for size 6 drivelines.
I believe the WoodMax driveline is a size 4 rated at about 40 HP. 84 inches of blower may be too much for that driveline. This is the second season I've had the blower and the first it was used on the rear. Due to severe drive line angles I only used the Woodmax drive line once and then mounted the blower with a quick hitch which required a longer drive line which was a size 6 that is now incorporated in the drive line to the front. If I have shear bolt problems I'll probably try drilling it out to 3/8" and start with grade 2 bolts. I realize I may find the weakest link in the snow blower and I'm OK with that. What's anybody's thoughts on using a slip clutch on a blower? You would have to be sure it's not rusted stuck before each season.
   / Got blasted in the Sierra with lots of snow.... #14
Please enlighten me, thought "shear bolts" were a FUNCTION and not a bolt type, bolt types are far as I know (common) are grade 2 (no head markings) grade 5 (three bars) and grade 8 (6 bars)... Metrics have numerical markings pretty much equivalent to SAE grading...
And soon as your snow blower eats a hidden rock or tree branch I belt you will be glad you did not go up in size because the blower did not eat some very expensive replacement parts that are only available this summer because of back order from people breaking them from using to large "shear bolt"....
Dale
   / Got blasted in the Sierra with lots of snow.... #16
You really don't want the threaded portion of the bolt in the shaft or shear area. The threaded portion will shear way sooner and will wear threads into the holes.
   / Got blasted in the Sierra with lots of snow.... #17
I don't understand the point you are trying to make DL Meisen. My snow blower and now my Wallenstein chipper both used grade 5 bolts at the shear point. The blower used 5/16" and the chipper uses 3/8". The Op manual for my chipper says - use either factory made shear bolts or buy Grade 5 x 3/8" bolts.
I agree, going up to grade 8 is not a good idea. Something other than the grade 8 bolt will - shear, break or grenade.
   / Got blasted in the Sierra with lots of snow.... #18
I have a woodmaxx 84" snowblower that keeps popping it's 5/16" grade 5 shear pins. Would I be asking for trouble if I moved up to a grade 8?
Maybe try an 8 millimeter bolt. It is a hair larger than a 5/16.
   / Got blasted in the Sierra with lots of snow.... #19
8mm is only .00246" bigger that 5/16" Never notice any difference. The Woodmax parts sheet does show the shear bolt as an 8mm.
   / Got blasted in the Sierra with lots of snow.... #20
By the way, Woodmax rates the 84" for 25-65 HP. Their driveline is likely only 42 HP if it is a size 4. A size 6 is rated at 69 HP and uses a 10mm shear bolt.
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
2020 INTERNATIONAL TANDEM AXLE SLEEPER (A58017)
2020 INTERNATIONAL...
2015 Chevrolet Express 4500 Shuttle Bus (A56858)
2015 Chevrolet...
Spreader Attachment (A56859)
Spreader...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2016 KUBOTA K008-3 MINI EXCAVATOR (A52709)
2016 KUBOTA K008-3...
