Got a loading problem with my new PJ deckover.
   / Got a loading problem with my new PJ deckover. #1
ShowroomShine
Raleigh NC
2019 Case IH 55A
Purchased a new 24 PJ deckover for my Case IH 55A and F250 today. I got the flip over ramps instead of the equipment ramps since I can fold flat and they are wider.
When driving up on the trailer for the first time with the tractor, once the wheels got off the ramps and onto the dovetail it picked the rear truck tires off the ground. The way the ramps are designed they don稚 support the weight of the dovetail or stop it from dropping.
I used jackstands to support the rear of the trailer for the unload, but that just seems clunky to do all the time for loading and unloading.
Any options other than welding some drop down support stands on the back of the trailer?
   / Got a loading problem with my new PJ deckover. #2
Used to have same problem with car trailer with ramps. Once it pushed truck forward which was freaky. After that jackstands and 4wd until I got my pj tilt bed deck over.
   / Got a loading problem with my new PJ deckover. #3
I’ve seen where people but what is normally on the front of the trailer, a crank down jack stand, and mount two at the rear.
   / Got a loading problem with my new PJ deckover. #4
If youre cheap like me, (2) 3- ton jack stands, or (2) 12 inch long chunks of 8x8 RR tie under back of trailer and a dunnage block place in front of truck axle front tire. :laughing:
If you want to spend, get a set of jacks.
   / Got a loading problem with my new PJ deckover. #5
Go drop downs. It’s the cheapest & quickest choice.
   / Got a loading problem with my new PJ deckover. #8
Correcting the ramps would be my first choice, so they are in place 100% of the time when needed and also lifted out of place when you're done. Drop downs would be my second choice but I'd paint the exposed leg a bright red or orange so when it's extended you're more likely to remember to retract them before driving away.
New/Unused 12ft x 7.4ft x 8.2ft Container (A51573)
New/Unused 12ft x...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A52748)
2023 NEW HOLLAND...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
