Got a little topless time in today.
/ Got a little topless time in today. #21
Can you engage the rear locker in 2 wheel drive? I could not until I did a modification on the Titan. It was set up from the factory to only engage while in 4 Low. The mod I did now allows it to be engage in any gear, 2 wheel, 4 high, or 4 low.
Chris
The rubicon it set up to only engage when in 4x4. Don't know it is did it in high or just low. With a modification you can engage the lockers when you want front or rear.
I put a set of rubicon axles in my TJ. Have the vacuum pumps wired on seperate switches on the console with a master switch under the 4x4 lever. They way you can't accidently engage a locker.
/ Got a little topless time in today. #22
So they use a air locker? My Titan has electric lockers. I was told they are Dana Axles and Detroit Lockers but to be honest I am not 100% sure.
Chris
/ Got a little topless time in today. #23
Kinda, but they were the original's. Well, from what I have read and seen, Bantam was, but...
Dad's was the Ford war production version; Willy's, like many other companies, could not keep up war production. Ford built tons of Jeeps during WWII. It had the frame mount for a 50 cal, and the bracing ect on the dash for a 30 cal mount. Also had the ammo lockers in the rear fender wells. And, a couple bullet holes... Although it was doubtful it was ever in combat; probably stayed Stateside for training ect.
That, and the CJ5(my Dad had, and I later bought back from the guy he sold it to) were fun, because we could fit where newer rigs cant. The later CJ's('77 and up) thru the new rigs are wider for road stability.
Buddy of mine has a newer Jeep; it is amazing how the new ones with coil suspension can articulate. Even if you discount lockers, just the suspension articulation will keep tires on the ground where they can get traction.
Sounds like the Suzuki Samaria my HS buddy had. That thing was unstoppable.
Chris
/ Got a little topless time in today. #24
Chris
Yep the ones in the TJ's use a vacuum. Just a single rubber hose run beside the vent tube that connects to the pumpkin. Don't know about the new JK's but assume they are the same set up.
Same principle as the auto hubs on the Fords. They run off of a vacuum.
/ Got a little topless time in today. #25
Gotcha, thanks. I knew there were air lockers, just did not know who used them.
Yea, I have had many of them Fords. Never had a single issue but it seem many do. I use my 4x4 weekly and never had a single issue other than a failed transfer case in a 89 Blazer. It always seems people who have issues with 4 wheel drive never use it then when needed it does not want to work. For that matter my father or BIL never had any issues either in probably 25 Fords in the last 15 years...
Chris
/ Got a little topless time in today. #26
Chris
I have a vacuum leak on my F250's 4x4 at the moment. Think it might be an O ring on the hub. The auto hubs are great when they work and very expensive to replace.
/ Got a little topless time in today. #27
Actually the TJ Rubicon models with front and rear lockers run off air pressure. Each axle has it's own little electric activated air pump. The hose is the pressure line going into the locker. i believe they use 5 psi but don't quote me on that, I've never checked the pressure.
They are designed with several restrictions in place. Can't activate at speed. Can't activate the front without first activating the rear. Etc., etc. But all that can be overcome with minimal electrical knowledge.
/ Got a little topless time in today. #28
Anytime there is a discussion about Jeeps someone always jumps in to talk about some old CJ or Flattie or WWII Jeep they were around years ago and how great it was and that it would go anywhere.
Kinda like me when I talk about my first new car, 1969 Mustang. In my memory it's the fastest, best handling car I've ever had. Sure wish I had it today....... If the car God dropped one in my driveway today I'd first take a hot lap,,,, then I'd pull it in my shop and start modifying it so it would steer better, ride better, stop better, go faster...... I'd realize quickly that my 40 year old memories are a LOT better than the car actually was.
Our oldest Jeep is a 1953 M38A1, next is a 1970 Jeepster Commando, then CJ, FSJ GW, YJ, TJ with the newest being an '05 TJ Sport. This fleet's offroad abilities are directly related to their age. The newer the better. Other than my homemade stuff, most capable being the '04 TJ Rubicon.
A lot of trails were blazed with the old Flatties and early CJs. But not without a lot of manual labor and at an extremely slow pace. And those early trails blazed a bypass trail around the most difficult obstacles. Now the trail goes to and looks for the most difficult obstacles. Those old Jeeps simply were not very capable offroad. In their day they were because no one else made anything to compete with them. But when compared to today's Jeeps,,,,, no race. But it's fun to imagine in our memories!!!! :laughing:
/ Got a little topless time in today. #29
I got confused. Remembered buying vacuum hose for the line from the pump to the axle.
/ Got a little topless time in today. #30
I whole heartedly disagree! While I will agree that the newer ones, especially the coil sprung ones, work awesome off road, I put that 70 CJ5 a lot of places. I did have, stock 4:88 and Powerlok, with a 2" lift. My Dad put it a lot of places stock, including early 70's Rubicon before lift kits and big tires. Mostly I had the 2" lift because the stock springs were worn out.
My buddies Rubicon('04 I think) works awesome, but he has put in a Rubicon Express long arm lift, gears, 35's, and other stuff. It is a lot cushier, and roomier. Real plasticy though.
And, I see the new Jeeps using the bypasses; they don't want to scratch up their $30,000+ rigs!
FWIW, I do not know of anyone with a new or old Jeep, that runs trails, that leaves them stock anyways. With simple mods, those old ones will go a lot of places.
/ Got a little topless time in today. #31
nice jeep......do they make them in colors for men? :laughing: just kidding had to go there since we always tease a buddy of mine for having a yellow jeep.....anyhow I'm with ya on the jeep thing....no doors and no top driving is the best....here's my 86 cj7 down at the river behind the house
/ Got a little topless time in today. #32
Here is my TJ after a lot of work.
/ Got a little topless time in today. #33
We'll just agree to disagree. Not much way to prove it unless we wanna get together and wheel.
I certainly would not say old Jeeps won't go anywhere. A lot of mountain trails used today were opened in those old Jeeps. It just came with a lot of work on the operators part. A good friend of mine, now deceased, Richard Ward, opened a lot of trails in South Central Colorado with a basically stock CJ5.
A CJ5 in stock format will go where a modern SUV won't. But it won't even stay within sight of a bone stock TJ. Never mind the Rubicon model,,, that's a total different subject.
All manufacturers and most Jeep owners will agree the Rubicon TJ is the most capable, out of the box, production line vehicle ever built. Subject to your debate of course. :)
/ Got a little topless time in today. #34
Nice pics. I really like the CJ sitting in the river.
Here's a picture of my YJ sitting in the river.
Then I added a couple above water so you can actually see it..... :cool:
/ Got a little topless time in today. #35
Hey, I resemble that remark about yellow Jeeps!!! ;)
/ Got a little topless time in today. #36
If my wife had here way ours would be yellow but could not find one in our price range. Don't really love the red but it was what I wanted for the money I had.
Ha! Thats funny. I've never owned anything yellow until this JK. My last Wrangler was tan. I was gonna get a green one but this one had a few more factory options. The Detonator Yellow is very bright to say the least. I like it with all the black. I dig your CJ. Nice pic in the river. Here's mine crossing one of my favorite trout streams in N Georgia.
/ Got a little topless time in today. #39
I would agree one of the new ones would do great stock. Even a stock '70 CJ5 with original powerloks would not match the articulation of the new ones. But it would not be far behind, and on most trails would do just fine.
And, as I mentioned, I have never seen many a stock Jeep. Heck, even in '68 my Dad and Uncle were putting longer shocks on, 11.50x15's...
Rubicon's... Been off and on doing that forever. Jeeps, thumper dirt bikes, 2 stroke dirt bikes, hiking, mountain biking...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2025 Grapple Hydraulic Mini Skid Steer Attachment (A61567)
2025 Grapple...
2014 FORD F-350 SERVICE VAN (A62130)
2014 FORD F-350...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
LandHonor LHR-AIW1 1in Air Impact Wrench (A60352)
LandHonor LHR-AIW1...
