Disc Harrow Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help.
   / Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help. #1
spareparts1
Fort Worth, Texas
Kubota L3400
A friend of mine got a new disc and he gave me his old one... Yeah... the frame was "repaired" (welded wierd) when I got it, so I cut the thing back apart and huck-bolted it together (the best welders I know are very discerning about when to weld and when NOT to).
Anyway, I've started taking the thing apart, looking at finding new discs for it, but it seems I need some disc bearings as well. The one I pulled off had the number, "651287-R2" on it. I suspect I am going to have to get second-source parts because I can't even find this number on cross-reference lists.
I attached some pictures. I appreciate any help!
   / Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help. #2
Re: Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little h
Looks like it needs to soak in diesel then greased up.
   / Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help. #3
An old .... used & abused..... cheap angle frame disc.....
Are you (OP) absolutely convinced that it is worth a rebuild?
   / Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help. #4
Those box type bearings have a lot of slop in them when new. Ken Sweet
   / Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help. #5
According to this thread:
Disc harrow bearings - Farmall & International Harvester (IHC) Forum - Yesterday's Tractors
The number you pulled off is the bearing housing, not the bearing itself. Try cleaning it up really well and see if you can find a number on the actual bearing, then you should be able to cross reference it.
   / Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help. #6
I'm with fried. Put 200 bucks in this thing and you've spent too much. I think you'd be further ahead to get a good working disc. Or a heavy disc in equally bad shape for small money and fix it up. At least then you'd have something of value.
   / Got a "free" 6 foot disc and I am looking to rebuild it, but could use a little help. #7
I think you will find the bearings at ASC - Agri Supply has farm supplies, tractor implements & mower parts.
There is a lot of slop in the bearing. It is filled with grease. They are also know as "Friction Bearings". I do not replace unless they break.
2005 Dodge Ram 4x4 Crew Cab Pickup Truck (A55852)
2005 Dodge Ram 4x4...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A56858)
2018 Nissan Titan...
UNUSED FUTURE D39 39" HYD TRENCHER (A57193)
UNUSED FUTURE D39...
UNUSED SDLANCH SDLC2020 - 20' X 20' CARPORT (A57193)
UNUSED SDLANCH...
