Got a 2012 M7040 for my first tractor.....couple questions
   / Got a 2012 M7040 for my first tractor.....couple questions #11
I open the hood over the engine compartment. Tractor, truck, ATV, lawn mower. Seems that mice & chipmunks do not like the open environment.
   / Got a 2012 M7040 for my first tractor.....couple questions #12
welcome to forum, & congrat on a highly sought after tractor. i find dryer sheets are short lived, i like bulk mothballs that i put in a sock & hang in engine compartment & close to panel. of course change engine oil/filter (recommend OEM), the hyd fluid may not need changing, you could get an analysis.
& yes, leaving hood opened helps a lot too w/varmints, & check the ft axle level, plus the wheel hubs (on mine they are separate reservoirs) the ft end usually comes from factory with hyd UDT fluid, i changed over to GL5 80/90 gear oil. or you could go full syn 75/90 gear oil but it gets pricey
is your model hyd shuttle or shuttle shift? no matter, both are outstanding
thumbs up on your purchase & welcome here
   / Got a 2012 M7040 for my first tractor.....couple questions #13
Put a piece of ¼" hardware cloth over the air cleaner intake. Keeps rodents from chewing the filter and filling the housing with acorns and such.
   / Got a 2012 M7040 for my first tractor.....couple questions #14
If the exhaust outlet is low maybe stuff a piece of steel wool in it to keep mice out. Did this with snowmobiles during off season.
Thanks for all the info. It's a Hyd shuttle so I shouldn't have to block the clutch pedal.
I'm thinking I should probably drain, flush and replace the coolant. I'm guessing it's never been done on this M7040. Just going to guess it's not too different from a car as far as needing to remove the thermostat before flushing and replacing with a new t-stat and gasket?
Any idea about how much distilled water I'll need? Also, any specific recommendations on anti-freeze brand/type?
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
2019 JOHN DEERE 17G EXCAVATOR (A52707)
2019 JOHN DEERE...
UNUSED FUTURE FT-LJB12 POLYTHYLENE BOARD (A57193)
UNUSED FUTURE...
6' ROTARY MOWER (A57192)
6' ROTARY MOWER...
2000 Morbark Towable Brush Chipper (A55851)
2000 Morbark...
Dump Truck Body with Tarp System (A55852)
Dump Truck Body...
