gorilla glue clean up?
   / gorilla glue clean up? #1
goaliedad
NORTHWEST MICHIGAN
KUBOTA L175
Has anyone found a solvent that will clean up gorilla glue from your hands? I'm glueing up alot of panels, and I know what the instructions say, but.....is there anything other than time that will clean this stuff up once it is cured? I was going to try fingernail polish remover, but the wife is out. Thanks in advance.
   / gorilla glue clean up? #3
I love Gorilla glue. It only has one drawback that I'm aware of. You don't clean it off. You wear it off. /forums/images/graemlins/blush.gif
Wear it proudly. /forums/images/graemlins/grin.gif
   / gorilla glue clean up? #4
That's kind of what I thought. It could be worse I guess, at least the stuff doesn't turn your skin red, or purple!!
   / gorilla glue clean up? #7
Hi goaliedad,
I think you're right to go with acetone pre-cure--get the straight stuff instead of nailpolish remover--like fiberglass resin--post-curing though, you've got a chunk of plastic! /forums/images/graemlins/crazy.gif
Skin grows fast though! /forums/images/graemlins/wink.gif
   / gorilla glue clean up? #8
Hi goaliedad,
   / gorilla glue clean up? #9
goliedad,
You might try this stuff call "Goof-Off". You can get it at just about any hardware store or a Lowe's or Home Depot. It's a solvent that removes about everything I've had stick to me. However, I've never tried it on gorilla glue...never had any gorillas.
   / gorilla glue clean up? #10
goliedad,
2020 FREIGHTLINER M2 106 BOX TRUCK (A54607)
2020 FREIGHTLINER...
1977 Ford F100 (A53422)
1977 Ford F100...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55301)
UNVERFERTH 330 -...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2025 Splash 20ft T/A Flatbed Tilt Trailer (A52377)
2025 Splash 20ft...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
