Gooseneck Trailer Ball height
   / Gooseneck Trailer Ball height #1
Creamer
Elite Member
NE Indiana
1710 Ford, Versatile 150
I have an IH4700 Single axle with a diesel engine (GVW 25,999). Is it possible to pull a gooseneck trailer with this or is it too high? If somebody did it how did you do it?
   / Gooseneck Trailer Ball height #3
I agree that most goosenecks have an adjustable column that you can use to level the trailer. Depending on your local laws and how strictly they are enforced pulling a trailer may require a CDL since the gross combined weight rating will be over 26000 lbs. My state doesn't get to involved with smaller trucks seems to vary state to state.
I have a 14' flatbed on it now but it is in rough shape and probably needs replaced. The cab needs some work as well but other than that the truck is in great condition,i.e. virtually new tires, brakes, springs, fuel system, etc. It runs great - just needs to refine some creature comforts, paint, and the bed has been abused.
Interesting photo of gooseneck hitch on semi tractor. My concern is getting the trailer hitch to reach through the bed.
   / Gooseneck Trailer Ball height #5
You see them all the time pulling big gooseneck living quarters horse trailers. Most use the IH 4700 LP (low profile) chassis. Like was mentioned the trailer coupler adjusts.
   / Gooseneck Trailer Ball height #6
If it's a full height chassis with a deck on it you will either need a custom nose on the trailer, or live with a nose high trailer, or recess the receiver in the deck
I do have a full height chassis with 10.00-20 tires on the rear
   / Gooseneck Trailer Ball height #8
That is the normal tire size. Specs show your top of frame rail height at 37.8", 34.8 for the 4700 LP. A GMC 2500 HD 2WD has a cargo floor height of 38.6". Mine are 4WD and sit up a little higher. A bed should not add more than 4"-6" inches to the ball mount height and that would be without a recessed mount. Both of my GN trailers have at least 18" of adjustment up. Any bed manufacturer should be able to give you the exact height of their ball mount on your chassis. If you have air ride you could add a dump valve for hooking up which is a common feature. I don't see you having any problems.
Don't forget to post pictures after. Remember the TBN rules, no pictures, it didn't happen.:)
Thanks! i will have to take some measurements and see what I can come up with. I know the bed adds more 6" - I am sure over 12" but I will take some measurements.
   / Gooseneck Trailer Ball height #10
Usually the cross members sit on the chassis frame rails so you have 3"-4" of height plus the steel or aluminum plate, another 1/2" or so. The bed frame rails are bigger but run along side the chassis frame rails. Here is a CM with 3" cross members and a trough between the frame rails so you can get an idea of how low you can get. This one looks lower than my pickups.
2020 JLG 1732 16,755lb 4x4 High-Capacity Rough Terrain Telehandler (A49461)
2020 JLG 1732...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2019 Bobcat E32i Mini Excavator (A50322)
2019 Bobcat E32i...
2014 PETERBILT 367 (A50854)
2014 PETERBILT 367...
