Gooseneck hitch on dump body
/ Gooseneck hitch on dump body #1
VTSTEVE
Central Vermont
NH TC35D
I need possible solutions to the following challenge. I have an 18' gooseneck trailer. It came with the ball mounted on a 2' X 4' steel plate. Previous owner had the plate mounted on the bed of his p/u (transversely) - bolted through the bed and into the frame (w/spacers). I have an F-250 with a standard weight bed with a DUMP CYLINDER! The cylinder is located, of course, right smack in the center of the frame, right smack over the axle -- just where the ball (plate) would have to be mounted if I wanted to mount the ball "under" the bed and use a "trapdoor". It seems that my only choices are to ditch the trailer, get a second truck for hauling my rig, or removing the dump apparatus and bolting the bed down thus going back to a conventional setup. I know that with a more substantial steel dump body, there are ways to attach the ball to the body only (I have seen balls mounted somehow on the frame w/trapdoor but perhaps that is with twin cylinders leaving the middle open). Do I have enough strength in my stock bed to mount the plate only to the bed (with reinforcement underneath, of course? Are the pivot pins at the aft end enough to hold the body in place? Would I still have to figure a way to stabilize (bolt down?) the front end of the bed so the whole bed doesn't "lift up" as a load is being towed? I need to tow a NH TC35D w/ some implements = max total wt 7,000#? Tounge wt = ? HELP and thanks in advance.
/ Gooseneck hitch on dump body #2
Hey Steve
I dont know if this will help or not, but alot of the guys around here are mounting the GN hitch on the top side of the bed. Instead of going underneath, they bolt them through the top side by the fender wells. So theres a aprox. 4" wide by 4' piece of plate in your bed with the ball(coupler) I dont know if this would work for you or not... It works for them but I didnt like it because of the difficulty in removing, ive got mine welded underneath.. By the way there is a new system or about two years old that they weld underside, it has a handle that you pull it to drop the ball and push it to pop it back up..
/ Gooseneck hitch on dump body #4
I gotta agree with Richard, mount to the frame! John brings up an interesting idea though. If you could afford a couple of trapdoors you could potentially rig something to span the frame above the bed and go down on either side of your dump cylinder. Maybe a bracket under the bed the hitch could pin to on each side. My fifth wheel hitch pins to brackets on each side leaving the middle open.
Whatever you end up doing, do it to the frame /w3tcompact/icons/smile.gif
Thanks Richard Rob & John! OK OK, I'm totally bought into the "bolt to the frame" necessity - thanks for the graphic rationale! I'm intrigued by the idea of bolting (or rather "pinning") the plate on either side of the cylinder. Please explain a little more about what you mean by "pin" and how you would envision it. Is it pins (bolts?) that are bolted/welded to the frame on the sides that stick through the bed with the plate attaching over them? Is it pins (bolts?) that stick down from the plate that attach somehow below the bed onto the frame? The latter would certainly be possible with a couple of trapdoors but short of bolting onto the frame (a real process) every time I attach the plate, I can't figure a way. Some kind of pins or quick-connects or ?? that make the connection between frame hardware (bolted/welded on) and plate & bolt/pin assembly up in the bed. Am I on the right track? Any thoughts on how? HELP!
/ Gooseneck hitch on dump body #6
Richard thanks for pointing out my, Lack of descprection on the way to mount on top of the bed.. What I meant to say was they have the hictch mount bolted through the bed and through the frame next to the rear fender wells.. which is where the frame is.. I personnally dont like bolts for goose necks but some do.. I believe ford has a clause about no welding on the newer fords.. At least that is what the shops around here say..
/ Gooseneck hitch on dump body #7
Richard thanks for pointing out my, Lack of descprection on the way to mount on top of the bed.. What I meant to say was they have the hictch mount bolted through the bed and through the frame next to the rear fender wells.. which is where the frame is.. I personnally dont like bolts for goose necks but some do.. I believe ford has a clause about no welding on the newer fords.. At least that is what the shops around here say.. Thinking about what the orginal post was about now this would not work for a dump bed,, obvious to me now..
/ Gooseneck hitch on dump body #8
VTSteve, I'll describe my fifth wheel hitch. It's a run-of-the-mill Reese. It has two rails that mount cross-wise in the bed. These bolt through the bed into some brackets that are bolted to the frame. They are always in my truck. The rest of my hitch sits on the rails and has ears that penetrate at the four corners. Through each of these ears is a 7/16" pin (like a reciever hitch pin) and clip. Makes it easy to remove, yet secure for towing. You might search on "Reese Hitches" for some pictures. Reese makes a Gooseneck adapter that mounts to the same rails.
It seems with some inginuity, you could come up with a similar arrangement that kept the mounts below the bed through some trapdoors. The hitch legs might have to be a little longer to reach, but the concept would be the same.
Hope this helps /w3tcompact/icons/smile.gif
/ Gooseneck hitch on dump body #9
John,
Yes you are right Ford does say not to weld to the frame. I guess it has to do with tempering but am not sure.
/ Gooseneck hitch on dump body #10
Some of the big truck manufacturers even put stickers directly on the frame warning against welding on the frame, and yet it's done every day at the dealerships. Product liability CYA.
Bird
/ Gooseneck hitch on dump body #11
Steve,
Any way to post a picture of your setup? Be alot easier to recommend a hitch if it was possible to see the setup. Also go to the reese hitches website. They have a number of do it yourself hitches and they may have one that might work for you.
/ Gooseneck hitch on dump body #12
I've seen the "no welding" stickers as well. Probably a combination of 1) liability, 2) loss of heat treat and 3) potential stress riser if the weld undercuts the base metal.
I think I'll heed the warnings /w3tcompact/icons/smile.gif
Case IH 950 Planter (A63688)
Case IH 950...
2016 Ford Fusion Titanium Sedan (A61574)
2016 Ford Fusion...
2002 Chevrolet C7500 MTI 805B-47 47ft Bucket Truck (A64194)
2002 Chevrolet...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2000 Malibu (A62613)
