Gooseneck Dolly
/ Gooseneck Dolly #1
Bird
Rest in Peace
Corinth, Texas
This afternoon, at I-35 & U.S. 380, I saw something I'd never seen before; a pickup truck with a dolly hooked to the standard hitch, and a gooseneck trailer hooked up to the dolly. I looked on the Internet and found this Gooseneck Trailer Dolly that isn't exactly like what I saw, but sure is close.
I can remember when some RVers? used a dolly to attach their trailers, which was then attached to a trailer hitch on the car, before frame mounted load distributing hitches became common.
/ Gooseneck Dolly #2
Bird, that sure is interesting. I wonder if you can move a loaded trailer with it? Would be handy in the fields putting out round bales off a trailer.
/ Gooseneck Dolly #3
From the looks of the one Bird posted, it looks homemade. I'm sure just looking at the pic someone could build one similar and use it as Deerefan suggests. I know I could but no longer have a need to do so.
/ Gooseneck Dolly
The one I saw was painted white and didn't appear to be homemade, although it may have been. It was parked off the street off the SW corner of the intersection. Since I was turning in pretty heavy traffic, I didn't get a real good look; not sure what the pickup was that it was hooked up to, and just for a wild guess, I'd say it was about a 30' gooseneck, and no load on the trailer. There's some construction going on at that location so again, just a wild guess, but maybe some the construction equipment was brought in on it.
/ Gooseneck Dolly #6
I have seen a dolly used by local farmers around here but they look more like modified Semi Tandem Dollys. I have also seen on the net but not in person a thing that clamped to the rear bumper or rear hitch and had a wheel that swiveled 360deg like a shopping cart and then would accept either a 5th wheel or a GN.
Chris
/ Gooseneck Dolly #7
I've seen them advertised some where and don't remember what the advantage was. The only thing that I can think that it offered was an additional braking axle. ... and your PU bed back!
/ Gooseneck Dolly #9
I wonder how difficult these rigs are to back up? It seems to me that the extra pivot would make for some fancy driving in reverse. But it is a clever solution.
SimS
/ Gooseneck Dolly #10
You see ones for semi trailers a lot and are called Joe-Dogs or Jeeps. I made one to pull my manuer spreader behind my ATV due to the hitch height and the toung weight. I saw one used by a guy delivering goose neck stock trailers. He had one behind the first goose neck pulling another. As far as backing up behind the ATV was not bad. Not sure how you would do it with double trailers for any distance.
Dan
/ Gooseneck Dolly #11
Safty hitch is the one that they sell there at 380 and 35 . From what I can tell it doues not pivot, it ties into the bumper. They have a nifty video on there.
/ Gooseneck Dolly
/ Gooseneck Dolly #13
Dan
I can tell you that regular semi-truck doubles are a bear to back up even trying to stay in a straight line. You cannot really see the "jiffster" or "dolly" or what ever you wish to call it until it is out of line enough that you need to start over just trying to stay straight. Some drivers do get pretty darn good with them though.
All things seemingly related when it comes to various laws and the combinatioins we talk about on this site, pulling doubles with a non air brake application is murky as well.
From what I know, it is illegal in some states to pull doubles period. Some you can pull a fifth wheel/gooseneck and a tag along behind. I am thinking using a jiff is for the most part "verboten"?
Regardless, I absolutely would not want to share the road with the average driver running doubles with no 'long combination" training.
/ Gooseneck Dolly #14
We pull doubles around here. I have done so with a 30' BP trailer then a Jet Ski behind it though 4 states with no issues.
Guy across the street pulls a 35' 5th wheel and a 21' speed boat behind that. See it every weekend at the marina.
Chris
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A61573)
2015 International...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
Willmar Fabrication 915 (A64119)
Willmar...
(1) 30 GALLON (1) 100 GALLON OXY/ACETYLENE TANKS (A64281)
(1) 30 GALLON (1)...
1998 Fontaine 48ft. 38 Ton T/A Flatbed Trailer (A61573)
1998 Fontaine...
2011 Ford F-350 Utility Truck (A61573)
2011 Ford F-350...
