Red Horse
Veteran Member
- Joined
- Dec 12, 2010
- Messages
- 1,155
- Location
- Bolton, MA
- Tractor
- Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Anyone have an opinion as to the relative accuracy of the Google Earth elevation figures? +/- ??
I work with Google Earth application and API every single day. The elevation terrain is not very accurate at all. This is why the licensing terms say that it should not be used as any sort of replacement for surveying or professional use.
The source is apparently SRTM data, run through algorithms to smooth it. That data is only accurate to 30m, which is pretty horrible for anything in which you would need accurate numbers. http://dds.cr.usgs.gov/srtm/version2_1/Documentation/MIL-PDF-89020B.pdf
I survey tens of thousands of points a year with RTK GPS. The elevations I get with it are sub inch. It compares very well with digital elevation models which is what I assume google earth uses. The only places I have seen huge busts is in areas with sharp and drastic elevation changes like on the edge of a small cliff. I have surveyed points a few feet (less than ten) from the edge on top and when I import those coordinates into google earth I sometimes get an elevation similar to down at the bottom. I think this is due to the grid size google earth uses.
All in all the elevations it provides are pretty dang good but I would not rely on them for anything critical.
Dave-does it suck up any more of your capacity. I'm clueless about such stuff unless I get my kids help. I use a Mac Book Pro.If you use Google Earth Pro. (which is free now) They state the accuracy for each scan of an area.
