Goodbye Kubota, hello EarthForce
Status
Not open for further replies.
   / Goodbye Kubota, hello EarthForce #1
MChalkley
Elite Member
Eastern Virginia
EarthForce EF-5 mini-TLB (2001)
Well, here's the latest in the saga of my decision to replace my Kubota. I never thought it would turn out to be such an involved process (though I'm sure some of you would say you expected it...), but, as usual, I'll report the long and the short of it to the gang here at TractorByNet.
First, the short of it: I've sold the Kubota and all of the implements that were for sale, but I'm not buying a Power Trac. That's about all I can say in a paragraph promising "the short of it" - everything else has to be labelled "the long of it", so now for "the rest of the story", as Paul Harvey would say:
A friend who has proven to be invaluable in his advice (whose acquaintance I met by way of TractorByNet) e-mailed me shortly after my original message concerning the Power Trac. He's an engineer by training and by trade, and I won't identify him, since he chose not to post his thoughts publicly, but the jist of what he said (relevant to my decision) was this (paraphrased in my words, not his): If you're thinking about an articulated vehicle, think carefully about the whole decision. Don't get hung up on the 3-point hitch, because that type of machine isn't designed for one. If you get a Power Trac, use it for a few months without even thinking about the 3-point hitch and see if you don't decide you don't even want one. He also brought out some thoughts on the differences in handling between articulated machines and non-articulated ones. The most pertinent one to my train of thought was the issue of close-quarters maneuverability. Specifically, I do a lot of work right up against buildings. In further test driving of the Power Trac, I found that it's just about impossible to get away from a wall (or fence, etc.) once you get too close, unless you use the loader and/or backhoe to physically pick yourself up and wriggle away.
After pondering all the implications of what my friend said in his original message, and in the correspondence that followed, for quite a long time, I decided to take his advice and carry it a step further: If it was likely that I wouldn't want a 3-point hitch on the Power Trac, this opened up all kinds of additional possibilities. I hate skid steers, so that's out. But, since since what's left is basically a Tractor/Loader/Backhoe of some form or another, further research was in order. As it turned out, the realization I ended up with amazed even me.
Some of you with better memories than mine may remember that I once posted a message asking if anyone knew anything about a machine called an EarthForce (back on 12/12/00, in fact). The message generated less response, by orders of magnitude, than any other message I've ever posted. (According to the stats, the thread has only been read 276 times to date.) At any rate, I have one making its way to me from Czechoslovakia as I write this. For the curious, it's the EarthForce EF-5: http://www.earthforce.com/ef5.html. Why did I make such a radical decision after being so excited about the Power Trac? Glad you asked...
I'm still no less impressed with the Power Trac than I was, just less convinced of its suitability to my needs. My needs, as I've said many times before, are probably atypical, so my decisions on equipment may be of value only in the sense of trivia to many of you. I won't bore you with a blow by blow description of the hours upon hours of research (and agonizing) I've done since my original decision to get the Power Trac 2465, or the trips to MD and SC to look at the EarthForce machines, but the summary of it all is basically this: If I totally abandon the idea of a 3-point hitch, all kinds of things are possible.
For one thing, there's tons of skid steer implements that mount on the front. The EarthForce machines use a standard "Bobcat-style" quick attach. (In fact, as of a few weeks ago, Ingersoll-Rand, the company that owns Bobcat, also owns Superstav, the company that builds the EarthForce. A number of Bobcat's implements are already being made in the Superstav plant in CZ, I hear.) Having a backhoe on the back all the time isn't such a bad idea, either. Plus, with the Bobcat-style mini-excavator quick attach that's an option for the EarthForce backhoe, and the available hydraulic outlets on the boom, I can attach an auger (and other things) to the backhoe. I use an auger a lot to plant trees and shrubs, so I can just back up to an area, spin around and dig a bunch of holes at once, instead of having to look over my shoulder for hours at a time and tediously position the tractor for each hole.
Another issue is the aforementioned maneuverability. The EarthForce features 4-wheel-steering in addition to full-time 4-wheel-drive, so it's quite a bit more maneuverable than my Kubota in a practical sense on a contruction site and doesn't tear up the ground at all doing it. An available option, crab steering, fixes the close quarters issue when I'm working against buildings. All four wheels turn the same direction, so you can move diagonally toward or away from the wall without the implements on the front or rear swinging into the wall.
The EarthForce line (except the largest, the EF-6) all feature hydrostatic transmissions, of course. The EF-5 also has a two-speed control which essentially uses an override solenoid to force the variable-displacement motor to maximum displacement, which produces maximum torque at minimum motor speed. (The EarthForce uses variable-displacement pumps and motors, while all CUT HST's I know of use varible-displacement pumps only.)
You can get the specs from the web link I posted, but I'll list the basics. It weighs 9300+ lbs; loader lift is 4850 lbs, breakout is 9370 lbs; backhoe bucket force is 7495 lbs, and dipper force is 4133 lbs. It's powered by a 56hp Kubota turbo engine, uses Carraro limited-slip axles, and Rexroth hydraulics. I ordered mine with 4-in-1 bucket, of course (which they call a 6-in-1 for some reason noone could explain to me), hydraulically actuated loader quick attach, backhoe quick attach, sideshift backhoe, auxilliary hydraulics, etc. One other feature I really like is that the 4-in-1 bucket uses a real construction-equipment-style separate spool with its linkage inter-connected with the standard loader lift and roll joystick. You can actually roll/dump, lift/lower, and open/close the bucket simultaneously!
The vast majority of the stuff I added to my Kubota, like lights, beepers, theft deterrence, etc., is already on the EarthForce, but they don't seem to realize how stupid it is to not have a tach, so that's on the enhancement list, as are some other things. It also needs Michelin XM27 tires - fortunately there's a size to fit. So, I'll still have plenty to do to customize it... /w3tcompact/icons/wink.gif
Sorry this is such a short message, given the gravity and radical nature of the decision, but ask any questions you like... /w3tcompact/icons/smile.gif Lots more details to come, of course. For one thing, I really haven't had time to talk about most of the design issues I really like about the EarthForce. For another, I'll have to report on all the implements changes...
MarkC
<P ID="edit"><FONT SIZE=-1>Edited by Muhammad on 11/03/01 02:28 PM (server time).</FONT></P>
   / Goodbye Kubota, hello EarthForce #2
Re: What a long, strange trip it\'s been-EarthForce
Mark,
Very, very, very impressive!
It seems like the best of many worlds… your pet Kubota engine, a bullet-proof Carraro drive train, all-wheel steering, Bobcat standard attachments, 22 ½ gallon hydraulic tank with the rest of the hydraulic horsepower, and the financial muscle and strength of Ingersoll-Rand Company is certainly a winning combination!
I’ve been on the lookout for a JD310x TLB for a friend, but after seeing this, I believe we are shifting gears and may go in this direction… He just bought a Lull All-terrain Forklift and needs something like this versatile machine to supplement the jobs.
WOW!…Mark, I’m getting excited… did I tell you I was impressed… /w3tcompact/icons/smile.gif
<P ID="edit"><FONT SIZE=-1>Edited by Muhammad on 11/03/01 02:29 PM (server time).</FONT></P>
   / Goodbye Kubota, hello EarthForce #3
Re: What a long, strange trip it\'s been...
Mark
You didn't mention that it has a <font color=orange>Kubota</font color=orange> V-2003T 56HP engine. Checked out the site. Looks like a workhorse. Did you order all the options? Cabin w/safety glass, Wipers, Heater, 6-in-1loader bucket, Quick coupler systems, Tools kit, Sideshift backhoe, Street pads, Road lights, Rockbreaker hydr. con. kit .. Or are these the upgrades and improvements you plan on doing./w3tcompact/icons/wink.gif/w3tcompact/icons/smile.gif
   / Goodbye Kubota, hello EarthForce #4
Looks similar to the JCB 200 series.
http:// [url]www.jcbna.com [/url]
4x4x4, sidesift, nice compact loader backhoe. Popular in the rental market.
Don't know how it compares for price and attachments.
Why, may I ask, do you hate skid steers?
   / Goodbye Kubota, hello EarthForce #5
Amazing . . . in more ways that one./w3tcompact/icons/wink.gif
Bird
RonH - Actually, I did say it has a Kubota 56 hp turbo... Good engine.
I ordered everything except the cab, wipers, tool kit, mechanical locking differential, and beacon. Road lights are now standard. But still, there are upgrades in the planning stages. /w3tcompact/icons/wink.gif
MarkC
PhatBoy - The JCB is about 40% more expensive and doesn't have HST. If you're a new member, you may not have been around for all the HST vs. whatever discussions, so you may also not remember my motto "No HST - no interest."
I hate skid steers because 1) I hate the skid steering concept specifically (in a tire vehicle) 2) I hate the skidding, and the damage it does to the surface 3) I hate the ingress/egress method 4) I hate the confined cabins 5) I hate all the operator lockouts 6) I hate the suspension, or rather the complete lack thereof 7) I hate only having one implement at a time 8) I hate the visibility. That's the best I could come up with in less than 3 minutes, and I'm sure I left out a lot, but that gives you an overall idea - like I said, I hate skid steers. I don't claim to have given them a completely fair shake, but I've used them a couple hundred hours, and I still hate them. No, that's not quite fair - actually, I loathe them.
MarkC
PhatBoy - Thanks for the links - I hadn't seen the second one.
MarkC
   / Goodbye Kubota, hello EarthForce #10
Rats - I was hoping to stop by to see your Power-Trac in action once you got it. Since my requirements are about 90% mowing, 5% FEL, 1% snow removal and the remaining 4% misc, including fencing, the Power-Trac 1430 is still my choice. Although working right against a wall or fence might be a problem for the articulated tractor, I think you'd have to slide sideways to get where you couldn't extract it. I experimented a little with the 1430, and decided that once I got used to a bit of suddenness in the controls, I could make pretty minute turns and movements, which would work out of trouble. (I've had conventional tractors against fences, too. A second tractor is sometimes necessary.)
Before you decided against Power-Trac, had you planned any exhaust modification to reduce noise, or was that not a discerned problem with the model you tested?
Charlie Iliff
Status
2015 ROCKWOOD T/A Travel Trailer (A51694)
2015 ROCKWOOD T/A...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
T3 Motion Patroller Segway (A51694)
T3 Motion...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
