Good truck experiences.
   / Good truck experiences. #31
I bet it was a 5 sp also,my 05 dmax had a 5sp,my friends 06 with a 8.1 had a 5 spd also. I was think the 6 spd come in with the body style change in 07,could be wrong theough. LUTT
The 06 got a six speed for sure. My neighbor has one with 90K on it that I have done every drop of maintenance on it.
Chris
   / Good truck experiences. #32
I stand corrected it is the five speed in the 04 - I was wrong once before. LOL! Still it is a great truck and pulls my 6000 pound boat/trailer combo just fine. I believe I will keep it!
   / Good truck experiences. #33
2001-early 2005 had 5 speed Allison 1000
2005 and newer has the 6 speed.
www.duramaxdieselspecs.com/allison_transmission.html
As for the Dodge truck transmissions, I find that they don't like fluid changes. Believe it or not but out of all the Dodge trucks I've owned and/or serviced, those WITHOUT fluid/filter changes lasted the longest. Just keep an eye on the fluid level. Even our old 2004 Chrysler Pacifica stated in the owners manual that transmission/transaxle fluid did not need service under normal use. Only extreme use (limo or taxi) required 100k fluid change intervals.
At 120k on my 03 RAM with the 545RFE auto and I will not be changing the fluid or filter. It was only low once in it's life (@80k) and took less than half a quart. A good friend of mine once said auto transmissions are full of ATF and magic, once you open that oil pan the oil and magic come out. You can refill the oil but the magic is loss. :laughing:
   / Good truck experiences. #34
Old Reliable...1979 F-100, a fleet truck I bought in July, 1987 for $2,000. It had a fairly recent rebuilt 300 cu. in. 6, 3 on the tree, manual steering and brakes. In 1991, I bought 2 F-100 parts trucks and rebuilt Old Reliable, adding 2 leaves to the rear springs and replacing the 3-speed with a Warner T-18 4 speed. Around 2001 the motor was totally worn out (piston slap so bad that a piston skirt broke), so I had it rebuilt. At the same time I had the radiator re-cored and I totally rebuilt the clutch linkage as it was also worn out. Around 2003 I added power steering. I have no idea of the mileage - I wore out 2 speedometers and was well along on the third one. I'm guessing close to 250,000 miles. Being an ex-fleet truck, it had the heavy duty bench seat (same as was in an F-750 I had way back then) and by the end of it I was practically sitting on the floor! In the over 22 years that I ran the truck, I replaced the heater core, driver's window operator and vent window, the clutch (twice), one set of king pins and the wheel bearings on a front wheel. Also numerous cab and body rust repairs. At the end of it the cab was so loose that it was like driving in a wind tunnel, but it still just kept on going. I ran the truck until December, 2009, when it got replaced with a 2000 GMC Sierra 1500. I sold it for $500 in the spring of 2010. I figure it didn't owe me anything...I only hope the GMC is half the truck it was.
   / Good truck experiences. #35
Chris
Tells ya how good my memory is:laughing:,I new my 05 had it,thought his 06 did also.LUTT
   / Good truck experiences. #36
Allison 1000 Transmission Specs
Thanks for the link Dmace. On tranny oil changes,the 88-99 chevy trucks were like,if you serviced the tranny regular,you were okay,if you waited to long,most of the time,it would get the tranny from a service.Something to due with knocking some of the crud loose inside. Guys at the local Gm shop would even tell the customer after so many miles of not servicing the tranny,you better just leave it alone. LUTT
   / Good truck experiences. #37
Best truck is easy. It's my 93 f150. I bought it new, used it as a daily driver for 17 years, it's now my hunting truck. In 20 years it has had one fan belt, two sets of brake pads, one set of brake shoes, two fuel pumps, one starter, two u joints, one ac compressor, one window motor, rear main seal, and a two sets of plugs. The transmission has never been touched and the valve covers have never been off. This truck has been used as a truck should be used and has stood up to the test of time and use. When I wanted a new truck (didn't need) I didn't even consider anything but a Ford.
   / Good truck experiences. #38
My best truck that I've ever owned is honestly a toss up between a 1995 Toyota 4x4 pre-Tacoma, 1995 Nissan reg. cab 2wd, and a 2004 Silverado Z71 extended cab. The 95 Toyota was my first vehicle ever and I kept it for 9 years. You don't want to know all that truck went through! All I can tell you is I put 129,000 HARD miles on that truck and when I sold it I got $8,600 for it. never had a seconds trouble from it. Replacing the timing chain at 100,000 miles was costly though ($900 job).
The 95 Nissan was my grandpa's truck and when my grandmother passed she still had it so I kept the truck and another family member took the car. I used that truck for years as a back-up truck to my 04 Z71. That little truck would get 25 mpg all day long. Never had a lick of trouble with it either. When you shut the doors on it your ears would stop up. I sold it back in 2007. Wasn't planning on selling it, didn't really want to sell it but this guy who has a reputation for buying folks cars for cheap and then turns around and sells them. Well I knew this going in so I REALLY stuck it to him. $5,500 and I wouldn't budge. He kept trying to offer me $3,000 but I just told him to go away because I knew what he was doing. I said "if you want the truck so bad you have my price, either pay me what I want or stop bothering me about it." He showed up with the $5,500 a day later and acted like I had taken food out of his family's mouth. Riiiight. You wanted it, bud. I ain't trying to give stuff away that I wanted to keep in the first place and you wouldn't take no for an answer numerous times. he was just mad because what he paid for it he couldn't sell it for profit. To this day he won't ask me to sell a darn thing else.haha
my 2004 Z71 was a good truck. I hit 3 deer with it over the 8 years I owned it, had a dash cluster go out in it. never had a bad hub bearing assembly go out and that seems to be an issue with this year model truck. I guess mine was built on a Wednesday.
   / Good truck experiences. #39
Just had the best experience ever with my 2007 Powerstroke.....when I dropped it off at the VW dealer and came home with my new Jetta.
   / Good truck experiences. #40
Neither of my 200K Chevy 1/2 ton 4x4's ever had a tranny fluid change and never caused me any problems either...My bad, I know..
Did change the traansfer case and tranny fluid in the wife's Hummer at 45K...All synthetic and priced accordingly.
2018 Forest River Grey Wolf 26RR Lmtd Toy Hauler (A52384)
2018 Forest River...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A51691)
Miller Trailblazer...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
2017 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2017 Chevrolet...
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
