Deere Dude
Elite Member
- Joined
- Feb 10, 2011
- Messages
- 3,881
- Tractor
- John Deere 3720
If only a couple small cracks need to be filled just throw a couple chunks in a pour pot and heat with a weed burned until meltedAh, something like this would be the applicator 'kettle'?
Kraft Tool Co. Pour Pot GG961 - The Home Depot
Control the crack damages of your concrete floors with the selection of this amazing and effectively priced Kraft Tool Co.www.homedepot.com
Or this:
HOT TAR POUR POT
The Hot Tar Pour Pot is specifically designed to pour hot tar directly on the roof or surface. Features 4" wide pour spout and a D-style side handle.www.jescraft.com
This one looks slick too. More expensive but would be a back saver.
Marshalltown 3 Gallon Crack Filling Pour Pot On Wheels RED704989 For Sale | Asphalt Sealcoating Direct
Asphalt Crack Filling is easy with the Marshalltown wheeled 3-gallon applicator pour pot. If you perform asphalt crack filling services for parking lots or possibly just for your own driveway needs, this Pour-Pot on wheels is a must. This "Wheeled Pour Pot" will save you time and "backache"...www.asphaltsealcoatingdirect.com
Still not certain what to use for heating on the propane burner. Anyone have ideas on a heavy metal pot?
Rob
That first picture is the pour-pot for dispensing rubber that I use. For bigger jobs, my turkey fryer is just an outdoor heater like this.
Backyard Pro 21" Tall Outdoor Gas Range / Patio Stove - 55,000 BTU
This 21" tall Backyard Pro patio stove / range brings your stockpot full of steamed vegetables or deep fried turkey to a comfortable working height for delicious results every time! Its powerful 55,000 BTU burner quickly and evenly heats the contents of your pot or pan and is equally at home...
You don't need anything fancy for a cooker. I used the steel 18-24 quart steel pan insert from a junk turkey roaster like this.
Just a leakproof pan about 6-7 inches high with a good edge so the pan of hot rubber can be carried from the outdoor heater to dump into the applicator(Your first picture.)
Heavy welding gloves need to be used for that and HF googles are a must. It cooks at 450 degrees.
I had some scrap sheet metal for a shield around the outdoor heater to conserve lp GAS.
Two people minimum for operation, three would be ideal.
I carried my setup to the job using a 2x4' platform in the 3 pt hitch in my garden tractor. That keeps it mobile and at a nice working height.
My weed burner is 60-80k BTU and used for keeping the end of the applicator so rubber flows freely through valve.
A tip: If big cracks occur fill with silica sand or else another very fine free flowing sand. Then blow out the top 1/2-3/4" with weed burner so rubber isn't wasted.
Another tip I found: 50# blocks come in 2 individual wrapped 25# squares. Freeze the individual 25# squares in a chest type freezer if it is warm outside and freeze to zero degrees. Then use a log splitter to make chunks to 3-4" square or you won't cut them down. This makes it easier to melt and simmer until needed.
Good luck and keep is simple.
If spelling and lingo sucked it may be because I am on opioids since my knee replacement Wednesday am]nd am not really with the program.
