Good morning!!!!
   / Good morning!!!! #212,191
82.6F and sunny @ 13:30, heading up to around 84F for the day's high. Low this morning was 49F.
Spent the entire afternoon yesterday working on coating 8' and 12' square 4 x 4 posts. Didn't keep track of how many sides I got done.
Probably back to more of that today.
Moved the 12' round posts off of the wooden saw horses with the forks and onto the hay wagon to make more room for recently coated posts to dry.
Have one bill that needs paid.
At a minimum the hopper feeder needs refilled so probably get to that as well.
Beyond that see what else comes up.
Hope everyone is having a decent Saturday ... (y)
   / Good morning!!!! #212,192
   / Good morning!!!! #212,194
Ordered 15 quarts of Mobil One European Formula 0-40 to change oil on the van.
Fritz,
IIRC, your Sprinter is an NCV3 ... not a T1N like ours. And requires an oil that meets Mercedes spec 229.51.
I haven't really kept up with this stuff, but last I knew the correct oil for that vehicle was Mobil 1™ ESP Formula M 5W-40:
From the link:
Mobil 1™ ESP Formula M 5W-40 is an advanced performance synthetic engine oil designed to help provide exceptional cleaning power, wear protection and overall performance. Mobil 1 ESP Formula M 5W-40 is engineered to help prolong the life and maintain the efficiency of emission systems in both diesel and gasoline powered automobiles that require an oil that is approved against MB 229.51 specification.
AFAIK, the 0w-40 does not meet that spec.
FWIW ....
   / Good morning!!!! #212,195
   / Good morning!!!! #212,197
Thanks for checking
It says it meets the MB specs 229.5 but has an expanded range for viscosity
If you use that oil it may cause problems with your emissions systems (cat converter or dpf ?)
229.5 is not the same as 229.51
   / Good morning!!!! #212,198
Good (Sunday) morning. Overnight Low of 8.6C and it's presently 13.0C [heading to 20C, according to the 'Liars'], light overcast & calm. Apparently that's all going to change this arvo/evening with high winds & rain. 'Tis the season.
I've successfully transitioned 'into the future' by an hour = my radio/clock woke me at the correct time and all of my clocks have been changed. I'll get my ute's one prior to heading off to Church, which will be happening in a few minutes, and then the rest of the day will be His.
   / Good morning!!!! #212,199
Fritz,
From the link:
FWIW ....
that oil is no longer available. Looks to be replaced with Mobil1 ESP 0W-30
   / Good morning!!!! #212,200
67F clear sky.
Good day for outside mowing and blowing leaves,around 2;30pm breeze to steady 10mph wind started raining leaves :rolleyes: guess I'll know what be tomorrow again.
Plans for the evening...share bowl ice cream what some football until the eye lids get heavy which not too far off.
Enjoy your evening all.
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, 5,888 Hours Indicated, mounted on 2018 (A59076)
2018 Elgin Broom...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
2026 Quality Steel Dump Trailer (A56858)
2026 Quality Steel...
New Holland WorkMaster 37 (A53317)
New Holland...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
