Good morning!!!!
   / Good morning!!!! #190,751
Those things sure make a lot of noise, Mike. They regularly buzz the Orcutt place at what seems like 100 feet or so.
Loud is right. There were two of them, cool to watch. Especially when you can see the pilots. LOL.
Here is a black helicopter checking things out a while back.
   / Good morning!!!! #190,752
Drew, did you forget charger for your phone/computer?
only for the laptop
I'm web illiterate on phone and Ipad.
guess I should learn
good to be home, easy drive, go hot out and up went the windows and on went the a/c.
got food unloaded, need a rest.
got a bunch of pretty cool pics to load.
guns?
you want guns?
I got guns, really, really big guns
howitzers, 3 inchers, I think a 130mm, and the big girl off the battleship.
mostly grown in now but the Fort Miles area is aimed right at NJ across the water.
Had a bad night in Atlantic City? Come down here and lob a 16 incher up that way.
2700 pounds of joy
   / Good morning!!!! #190,753
that piece of armor plate with a hole it is pretty dramatic to see.
   / Good morning!!!! #190,754
Thanks for the replies fellows. I just wanted to try and understand how insurance rates are compiled. Seemed strange that liability coverage was so high on such old vehicles that were driven so infrequently. Guess it's take it or leave it.
Back to lurking.
   / Good morning!!!! #190,755
a few campground pics
then I'm taking a nap
then I'll go back about 20 pages and start again
   / Good morning!!!! #190,756
Good Afternoon,
Fiddlearound, I forgot to mention what company I’m using ! GEICO for both my truck and Kathleen’s Honda CRV !
You might try shopping around a little, you may get a better deal elsewhere !
   / Good morning!!!! #190,758
A much cooler 78F and generally overcast @ 14:45, calling for a high of 80F with a chance of a stray thunderstorm, possibly severe.
Thunderstorms came through earlier while I was sleeping, dropped 0.24" according to the LWS. Yesterday's high temp was 93.4F according to the same station.
I initially spent some time yesterday making up a few more cages with what was left of the 2' tall welded wire fencing.
Then I started putting the Bush Beefsteak tomato plants in the ground. Got 11 of those planted, watered, and caged, 1 teaspoon of bone meal and blood meal per plant.
Woman sprayed them (and the Sunny Boys) with neem oil solution:
Still a few left to do. They called for a minimum 2' spacing, I skipped every other hole in a row which had 18" spacing, putting them 3' apart ... figured we might plant beets in the holes that were skipped.
Woman found some frozen sauce in the freezer so She made spaghetti with garlic toast for dinner, along with a tossed salad. Was good, I was stuffed.
After dinner I potted up another 8 Green Envy tomato plants.
She's currently over visiting relatives.
Insect netting and landscape staple order from Amazon is now showing "delayed" ... 🤬
May see about getting a few more plants in the ground if storms hold off and I can find more staples for the cages.
Otherwise get cleaned up and maybe see about a haircut ... which is way overdue.
Hope everyone is having a decent Wednesday ... (y)
   / Good morning!!!! #190,760
Spent most of day calculating building costs. Compared SIPs vs framed, SIPs $23K more, except haven’t added insulation yet for framed. Lot of lumber you add to those panels. Did calculate using ZIP roof and siding. Don’t have framing labor costs in either.
Will cost $10k more to have a basement instead of slab on grade.
I did add concrete labor costs equal to the cost of the concrete, used $120 a yard, I’m sure I’m low. Did not add in the mud room cost, which won’t happen with a basement.
Lot has slope to do a walkout.
Took a swag at some costs. Found a lot of material costs from Lowe’s or HD.
Neither estimate includes doors or windows, roofing, siding yet which will be equal in both scenarios.
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
TEST YOUR BID BUTTON! (A52709)
TEST YOUR BID...
