Good morning!!!!
/ Good morning!!!! #178,121
/ Good morning!!!! #178,122
Good Afternoon Guys,
Scootr, best of luck with surgery!!
RNG, I bought a Craftsman pressure washer with the Honda GCV engine a few years back ! I think around 3000 psi, have had good luck with it so far ! I am partial to Honda engines, pressure washer, log splitter and portable generator ! They need to start without too much pulling ! 😉
Beautiful day, have a great afternoon !
/ Good morning!!!! #178,123
68°F and .01 inches rain
No clue what I might get into today.
first off is appointment with eye doctor if I get dilated that’s pretty much it as it takes me all day to recover.
Zoom Happy Hour this afternoon.
Prayers for all
Be safe
Have a great day
/ Good morning!!!! #178,125
There is a eye drop coming on the market soon to reverse medically induced dilation.
I have been watching that space for over 20 years.
/ Good morning!!!! #178,128
if at first you don't succeed, do it three times.
that's how my morning went.
Started off greasing the spindles, then put the new blades on
but the deck was so clogged with wet grass I couldn't leave it that way so made a big mess with that.
then took mower outside and degreased/cleaned/powerwashed the mower deck.
looking spiffy, blew it all off with air and decided to run the blades to dry everything out.
wack wack wack wack
sigh
I realize the new blades don't fit the same way, and took one off to compare with old one.
Aha, different size center hole, new one about 1/16 too small. So blade was not seating properly.
Ok, jack up the mower for second time and replace with spare set of sharpened blades.
take it outside to check and
wack wack wack wack
now I had lost my sense of humor.
went inside for some lunch to regain it, came back out,
jacked it up again, and
got it all installed properly and it ran fine.
had to be careful in jacking, tire kept trying to climb out, got it put back in where it belonged
sat outside for a few moments and watched stink bugs run along rv window.
/ Good morning!!!! #178,132
Good Morning Guys,
Ct, 55 to start going to 75 ! Leaving for Vt this morning, 51 there going to 73 ! Nice sunny fall weather ! Birch trees in Ct are really starting to fall, nice yellow color, but other trees not doing much other than the maples ! Should be interesting to see what Vermont is doing with color, usually peak up there is around Oct 10 th give or take ! Last year was really nice, some years not as much !
Thanks for all the TBN members pet pictures !!
Hope all have a blessed and safe day !! 🙏
Hope the ride north was smooth,next 4 morning you may need sweatshirt afternoon t shirt weather. :)
/ Good morning!!!! #178,136
Odd weather day so far.... every time that I head out to get started, it sprinkles..... so I stay inside.... 10 minutes later the sun comes out.... 10 minutes later, sprinkles again....
I guess, today is not going to be a work day. That's ok, need a rest.
Here is Max's contribution to the photo array:IMG_1057.jpeg
Took care of some paperwork, compiled more onto the grocery list, and now just chillin.....
/ Good morning!!!! #178,139
Coloration getting more prominent… still mainly poplars and sourwood’s, but a couple oak leaves are participating, too..
SHOP BUILT TOOL TRAILER (A58214)
SHOP BUILT TOOL...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A61307)
Adams Load Out...
2007 Amkus Rescue System (A59228)
2007 Amkus Rescue...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
