Good morning!!!!
   / Good morning!!!! #174,142
Since people are putting up pix of firewood projects, here is my stack for next year so far. It includes the trees from the work the other day and some that I fell as well, which need to be cut up into the appropriate length and all of it needs to be split:
and this is then current stack for the sawmill, which will contribute a lot of slabwood for the firewood pile too:
   / Good morning!!!! #174,145
I am getting a little frustrated with the little Toro blower I picked up yesterday.
it will run on ether (just enough to test). But itnis not getting gas. Pickup Filter is relatively clear.
I want to get a rebuild kit for the carburetor, which is a Walbro. It is a WY carburetor but no additional model number info is visible anywhere on the carb body.
The Toro part number is 65-3740.
The replacement carburetor prices run from $340 to over $1000. AYFKM??????
there are several WY rebuild kits available for $9-$15, but I need to know which one and I cannot find any cross-reference to determine the Walbro p/n from the Toro p/n.
   / Good morning!!!! #174,147
Good (Monday) morning. Overnight Low of 9.9C with very gusty winds. It's presently 14.5C and sunny with more howling winds later today. There was 4.7mm in the gauge @ 0900 and, yesterday, had 0.5mm.
I did dismount the flagpole in anticipation of the weather. It'll stay down until tomorrow.
No damage or trees/limbs down from last night's weather, although the gutter on the 'wood' shed has come down again... that's the third time this year so I'm just going to leave it down as it really doesn't perform any real purpose and I'd need someone to assist me putting it to right.
   / Good morning!!!! #174,148
Can you post picture of the blower?
It is dark and I took photos with a Horrible Fright utility light (the 99-cent one).carb is visible between pull handle and kill switch.
   / Good morning!!!! #174,149
Kilroy, once you get a model number, check on Ebay....
Here is one for a Toro blower, not sure if it's correct....
I have gotten these carbs for my previous rebuild of a string trimmer and for the garden tractor.... both are still working great for a few years now.
   / Good morning!!!! #174,150
M7040, I could venture a guess on your daughter's call up to the WH. Possibly because Russia is threatening to use Nukes...I honestly hope it's for a something good though.
She said this evening that it was personal and triggering and she would tell me about it when it goes public.
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
Pair of New 700/40-225 Alliance Tires with Rims (A53473)
Pair of New...
2016 E-Z Beever M12R Towable Brush Chipper (A50322)
2016 E-Z Beever...
