Good morning!!!!
   / Good morning!!!! #173,911
Chrome still shows ads between posts.
on 4th or 5th android to iPhone attempt. It keeps crashing.
   / Good morning!!!! #173,912
If it starts and runs, but not up to speed, does the motor have brushes ?
They may be worn.
Also drain any water and look for rust.
How do the motor/pistons get oil ?
Good Afternoon kenmbz,
I did drain what little water was in there ! There is no oil in the piston or sleeve area ! I still need to take off the motor cover and check that out !
Thanks for the reply !!
   / Good morning!!!! #173,914
I use Brave browser on my iPad and IPhone and it works seamlessly.
   / Good morning!!!! #173,915
Good Morning Guys,
67 now going into the mud 80’s, so another hot and humid day !
Popgadget, your an electrical guy ! My 6hp 30 gal Craftsman compressor is giving me trouble. When I try to start it it’s kicking my breaker, wants to start but kicks breaker instead ! I have read it may be the large capacitor on the motor ! Any feelings on that or a test I could perform on it ? I do have a meter. I’m a mechanical guy so not to good with electrical issues ! Thanks for your thoughts !
If there is a “hump” on the outside of the motor, that’s what the capacitor would hiding under. A failed capacitor would give you the symptoms that you described. Disconnect it, short the terminals with a screwdriver to discharge it (in case it’s good).
And measure it’s value compared to its label. The ability to measure a large cap is not usually native to a lower end multimeter, if you can’t measure it, and can’t find someone nearby that can, you could mail it to me.
   / Good morning!!!! #173,916
I haven't even gotten my e bike yet and they are pitching some inner tube inserts.
Mostly and other bikers, are these worthwhile?
I thought I had bought all the options already...not so
I have an air pump in the rv, and I'm not traveling far from it. I think.
hmmm. if I get a flat, what do I need? should I have a spare tube? It has a chain, do I need some specialized chain lube?
   / Good morning!!!! #173,918
Good morning, well afternoon......
Didn't sleep well again last night, slept in an extra 45 minutes this morning.
Then realized that Max had a first appointment at the groomer..... a little rushed, but we got there on time.
A good thing because she books out appointments 6-8 weeks in advance.....
Max is now relaxing.....
Took the opportunity to go grocery shopping, got everything except for one insignificant item. Perfect timing when done to pick up Max. I like consolidated trips. Being the groomer is only a half mile from the store.... worked out perfectly!
Already hit 98° so not much going to happen outside today except for monitoring the drip irrigation. I might try and brave the heat and clean the truck....but, tomorrow morning might be better.....
I think I talked myself out of doing it now.....
Scott VT, check the air bleed off valve too. I have a Rol-aire portable compressor that would do the same thing. The valve was causing a slight over pressurization which caused the motor to "overload" and trip the breaker.
I have never replaced the valve, but found if I drain the tank before trying to start it, it fires right up. Once it fires that first time, then it cycles normally. I don't use it a lot, so figured a few extra minutes is no big deal.
   / Good morning!!!! #173,919
high was 88 deg today. Antiquated posting from computer browser :ROFLMAO:
I've lost track of the number of android to iphone transfer attempts. Keep trying new things found in youtube videos, turn this off, set this, etc, etc.. And a lot of them the instructions don't match the version of android, so either have to find the new place for the setting or skip that one.....
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2012 WABASH 53FT DRY VAN TRAILER (A52576)
2012 WABASH 53FT...
LOT LOCATIONS (A52577)
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
