Good morning!!!!
   / Good morning!!!! #157,771
FtTomorrow (Monday) my wife goes in for a exploratory heart procedure about 11.00 am. Maybe a stent but it is mainly evaluation. Can't come soon enough as her heart has been doing dicky things lately. Family are coming to stay for the day/night.
Prayers for your wifey.
   / Good morning!!!! #157,772
65F clear sky great t shirt weather this afternoon. :cool:
Been good day...got everything done I wanted and little bit more. :)
Phil put snowblower on his Kubota last week and Roy just about ready to put snowblower on his JD....hmm,so I decided to change all fluids and filters also antifreeze,grease or spray lube points of interest,put tire chains on and rear blade follow by good bath guess I'm ready for winter. ;)
Mrs. going to BBQ some of buggers thinking 1 won't be enough :) later on share bowl vanilla with the kittens maybe watch little football or who done it movie.
Enjoy your evening all.
   / Good morning!!!! #157,774
I have lots of stumps and some bamboo I would like to remove. It would be an ongoing task as there are a lot of dead trees around the property that keep dropping branches that I would love to get rid of too. I also need to do some trenching work for power and water pipes.
A minix will do a good job for what you are talking about. I had a backhoe on the MF203 that worked really well but it does not even come close to what the minix can do. And with the thumb it can pick up branches up to 2000 lbs or more making it very convenient. Digging the stumps today took very little time even digging fairly deep on the big one. The lifting ability to load things and the ability to turn on a dime is great. And then the blade makes it easy to push the dirt back in the hole and then compress it with the tracks. I was not sure I needed it but now that I have it comes in very handy. The best thing is to rent one to see if you would like it before looking for new or used. The good thing about these is that they hold the value well so you can likely sell it for the same that you bought it for later. Also I generally use it on cold or hot days where it is comfortable with heat and ac.
   / Good morning!!!! #157,775
A minix will do a good job for what you are talking about. I had a backhoe on the MF203 that worked really well but it does not even come close to what the minix can do. And with the thumb it can pick up branches up to 2000 lbs or more making it very convenient. Digging the stumps today took very little time even digging fairly deep on the big one. The lifting ability to load things and the ability to turn on a dime is great. And then the blade makes it easy to push the dirt back in the hole and then compress it with the tracks. I was not sure I needed it but now that I have it comes in very handy all the time. The best thing is to rent one to see if you would like it before looking for new or used. The good thing about these is that they hold the value well so you can likely sell it for the same or more that you bought it for later
The only thing "bad" about buying a mini excavator is the money required.
I have little need for a mini excavator...but if I did, I'd rent. Good planning for multiple tasks makes the rental worthwhile, IMHO.
   / Good morning!!!! #157,776
Roy, agree they are expensive. In my case at least in my mind I justify it based on getting older and it allows me to stay on the farm and still do a lot of what I used to when I was younger and stronger
   / Good morning!!!! #157,777
If you have the money, go for it!!!
   / Good morning!!!! #157,778
Took MIL to see the lot. Met neighbor to the north and discovered they are the neighbor from hell.
Not sure what I’ll do now. Will have to talk to closing attorney about options. Might just try to flip the lot.
   / Good morning!!!! #157,779
How are they the neighbors from hell?
   / Good morning!!!! #157,780
October is typically one of the lowest months for rainfall here, so it's not entirely surprising ... although I'm not really sure how this particular month stacks up historically.(y)
I wonder if you couldn't incorporate some sort of tank to store water, with a level switch to shut the well pump off when it got full. Not sure how you'd keep the tank and plumbing from freezing in the winter, though.
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
2017 Chevrolet Trax LS SUV (A55973)
2017 Chevrolet...
2012 KIA Optima (A56859)
2012 KIA Optima...
JOHN DEERE 310K (A58214)
JOHN DEERE 310K...
2021 CHEVROLET 4500HD 16FT BOX TRUCK (A58018)
2021 CHEVROLET...
Case 621D (A57148)
Case 621D (A57148)
