Good morning!!!!
   / Good morning!!!! #149,121
66°F and 1.48 inches rain and raining.
Got about 90% of largest bench cleaned off. That’s encouraging. Also grilled another large wheel barrow load of lumber cutoffs during a dry period.
A repeat of yesterday is the plan.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #149,123
That reminds me, I need to look for truck battery.
   / Good morning!!!! #149,124
.. I did apply the change to the master inverter's power conservation setting, and while the lights still flicker when the phase converter motor starts, I couldn't find any sign of a voltage sag during the air conditioner start. The air conditioner compressor was previously the worst offender, so now I want to undo the programming change and rerun the test.
I installed these soft start devices on my heat pump compressors and they made a big reduction in startup current draw. Much better than a typical hard start kit.
I’m assuming that you have a rotary phase converter, they usually have a big inrush when they start due the capacitors creating the phase shift to get them started. I replaced the rotary that I used for my Bridgeport with a VFD. Now I’ve got variable speed and a very soft start.
   / Good morning!!!! #149,126
I’m assuming a bird flu victim.
Probably did not social distance.
"...in this current H5N1 outbreak, one consideration is to not encourage birds to gather together at places such as bird feeders or bird baths. These are places where things like viruses could easily be exchanged between individuals,” Hall said.
   / Good morning!!!! #149,128
Wishing you many many more trips around the sun LS. :)
   / Good morning!!!! #149,129
52F on/off showers most of the day into early evenly.
After putting in some hours at pt.job fnally got wood area clean level and the new wood pallets in place.
Before 4:30pm today leave pickup at our local mech. for greasing oil and oil filter change also radiator flush replace winter tires with summer tires.
Not much plan for the evening.
Enjoy your evening all.
   / Good morning!!!! #149,130
Perfect afternoon snack.
Slugs on a boat.
1 apple
3 dates
1 square 100% cacao
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MASSAGE CHAIR (A58214)
Year: 2023 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2023 Make...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2019 Ford F-250XL (A57148)
2019 Ford F-250XL...
