Good morning!!!!
   / Good morning!!!! #121,871
got the woodworking machinery placed and set up. Used digital level to make sure tables were level to .02,
wiped all the exposed machined or chromed steel down with some all purpose oil as a barrier against moisture and corrosion.
Which this garage has plenty of. Turned them all on, no unusual noises or vibration, then cleaned up the mess and put away all the tools.
most of assembly was with a compact Bosch cordless driver running an adapter and then a nut socket, the same size of which was thankfully the same
though out several items.
Main work table is height adjustable so I can make changes there if needed. Wanted to stand more upright so higher work surfaces work better for me.
The chair looks nice but has no back support so I'll continue to use the plastic chairs. 12.99 at True Value on sale.
First time I twisted on hose into one of the two vacuum ports on the table sander,
the thin plastic case at the end of the long belt cracked with a SNAP.
You have to be kidding me...
Hard to see but thin white line in photo from top of port to left of plastic. Nice three inch crack but the whole thing is intact.
This will make for an interesting gluing project, might need to see if I can get that plastic piece off the machine as dripping glue inside
a power sander can't end well. :rolleyes:
This is a very heavy sander but they skimped on plastic it seems for the belt guard. Of course, I did torque/bend it a little. Not much.
Not enough for snapping sounds...
There should have been more reinforcing plastic near the outlet, build some strength into the "structure" but clearly someone was trying to make this
as thin as possible. Follow the money.
Drill press has dual axis laser and is simply a decent quality Wen drill. I don't need a CNC guided fabricator to drill a hole in cedar boards for bird feeders...
So this will do nicely.
My goal is to build bird feeders and bird houses for all my extended family this Christmas.
I'd better get a move on.
But not tonight...
back hurts, good thing I'm seeing a Rothman surgeon tomorrow for a consult.
Maybe if I get a bird feeder up here, I'll get some bird pictures too.
   / Good morning!!!! #121,872
The firewood going into the basement aint gonna happen. It is pizzing down rain.
I assume pizzing rain is more than spittin
Dad’s power is off in Ohio due to wind
   / Good morning!!!! #121,876
No storm watches or warnings yet. 65° with south winds of 22 right this minute, gusts over 35. Looks like most of the rain is going to pass north of us, and we don’t need it right now.
Ellen made chicken tortellini soup, very good!
Piddled the El Camino for a while, put away more deck furniture, down to my chair and one more.
Bought a couple of Roku Premium units, got one connected, it’s great, I might get a good antenna and unplug the overpriced cable, between the 9 or so local channels, Roku and online streaming, I’m pretty well covered.
   / Good morning!!!! #121,877
Drew, it is too bad you can't roll some white paint on the walls. It would lighten it up in there.
Chris
   / Good morning!!!! #121,878
60 and falling quoted several jobs today nice ride in the country afterwards. Everything still very wet streams running high rivers too
Glad Coco is better she is a favorite on here
Nice pictures rswysn
Don sorry about your neighbor
Nice wood working shop Drew
Sleet/ snow snizzle
   / Good morning!!!! #121,880
Just got back from Pet Supplies Plus and Home Depot, winds still blowing ... can hear it inside the house ... but temps were tolerable.
Brought the trash cans in, but will wait until tomorrow when it's light out to bring in the rest of it.
Guy up at the end of the road had one of his pines sheared off at about 2' above ground ... just splintered all to heck. Was probably about 18" - 20" in diameter where it broke. Kinda surprising because it sits in an area that is somewhat sheltered. I guess with the leaves being off the trees, it's wasn't as sheltered. Other branches down along the way.
Road was closed in one place on my normal route over to the Depot.
Got the fish fed and finished up my Shrimp with Lobster Sauce from last night with some fried rice before I headed out, along with some more clean in the basement.
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
5'x8' Rubber Mats (A55272)
5'x8' Rubber Mats...
Heavy Duty 10,000lbs Two Post Car Lift (New/Unused) (A59225)
Heavy Duty...
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
2019 ALLMAND LIGHT TOWER(INOPERABLE) (A58216)
2019 ALLMAND LIGHT...
