Good morning!!!!
   / Good morning!!!! #105,311
My son had symptoms of heart issues last summer and went to ER. Turned out to be low potassium.
I was given last rites about 15 years ago due to low potassium. Guess I wasn稚 ready and not as far gone as the ER docs thought. So I pay a lot more attention to low potassium and staying in front of it since then.
   / Good morning!!!! #105,312
I have a bottle of potassium too, never used it, they say levels are ok. ?
Thankfully all of my labs are online and I can easily look them up.
Not now, need a break, put
rv under shed after unloading with all the fussing than entails, hooked up to power, autoleveling on so weight off tires, no flatspotting.
This is where I have no endurance, get tired too easily.
But chores done, exercise actually felt good.
Realized I hadn't drained the fresh water system so back down I go later. Front coming through with much cold weather tonight, around 26. Need to drain water tank and small instant hot water tank. Need to put some pink stuff in a few lines too. I keep low heat on all the time to keep the humidity/mold out.
Ron, I took pictures and not much to see. Found specs and serial number of awning, it's externally attached and cover actually looks designed to break off on plastic tabs. It's the first point of contact on that outside corner.
At issue is anything else other than the cover missing. Doesn't look like it but I'm sure not testing if to see if awning still works or if mounts are torqued in any way. At fourteen feet long I can't put it back on anyway so let the dealer test it. Going to email these pics to parts dept. first.
Awning is on right side of unit looking forward. Sure wouldn't have liked to wack the other size, more machinery over there...
Need to read instapot manual while resting.
   / Good morning!!!! #105,313
Should be able to find parts for awning. Should be a tag someplace with model and serial number. Usually on awning fabric.
   / Good morning!!!! #105,314
Doctors don't give a rats behind if you have side effects from a particular drug. It just gives them an excuse to write yet another prescription for another drug that will more than likely have its' own side effects. I do NOT trust them as far as I could throw them. My doctor from 1965 until 4 years ago finally retired, she got it right. They don't call it a 'practice' for nothing you know.
   / Good morning!!!! #105,315
Ron, that info came on a nice list of component parts of the entire rig. Have to call Tuesday and send the pics to dealer. Made by Carefree, whoever they are.
Bill, I have serious arthritis and SDDD and have been pilled out for a long time. Could never have worked this farm without Celebrex for arthritis. I was supposed to be in a wheel chair ten years ago per the pros, and I just work through the discomfort.
why not have an intelligent software, in case you can't find competent medical folk to do it, to kick off a list of potential medical incompatibilities and make it required to point them out? I'm not thinking like a lawyer but as a guy who has likely been overdosed and under monitored...
   / Good morning!!!! #105,317
Potassium, sodium, magnesium, calcium, doesn’t matter, any electrolyte imbalance can cause those symptoms. Their balance is critical to heart function and lots of other stuff.
44 here, windy but temps didn’t fall rapidly all day as predicted.
Got pork roast, baby potatoes, onions and carrots in the slow cooker.
Ellen is up and about but still showing head cold symptoms.
Prayers for the health of all.
   / Good morning!!!! #105,318
very interesting Rick, worth the time, which few infomercials are...
This is very common in Bermuda and many other islands, makes the roofs very pretty, everything spotlessly maintained though you have to wonder about
bird poop... and what that gull ate before you...
In a dry region, this is really good to know. Plus the whole idea of self sufficiency is appealing.
Once there was a traveling salesman in a post apocalyptic world, where gangs fought to control the water sources,
and you just smiled at your Water Wonder install, never have to worry about water again.
As history as shown us water
is a big deal...
I think I'd buy a tornado shelter first...
   / Good morning!!!! #105,319
is a big deal...
A lot of folks, in Texas, harvest rain water, to one extent or the other. I've thought a lot about it with all the roof area of ranch house and big shop building.
We just barely exceeded 40" of rain in 2019.
   / Good morning!!!! #105,320
very interesting As history as shown us water is a big deal...
A very big deal indeed. In Kalifornia it was illegal to harvest rainwater until 2012, when a new law went into effect to allow homeowners to do it. it was driven by the droughts and the need for water to fight fires in rural areas.
New/Unused Self Dumping Hopper (A54865)
New/Unused Self...
Pallet of Heavy Duty D-Ring Shackles (A53425)
Pallet of Heavy...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
CAT 973 (A47384)
CAT 973 (A47384)
2018 KENWORTH T800 DAYCAB (INOPERABLE) (A55745)
2018 KENWORTH T800...
