Good morning!!!!
   / Good morning!!!! #95,461
70 outside this AM. Heading to upper 80's. Chance of storms today. Missed us yesterday. Looks like a pool day.
Have a great day all. Be safe.
   / Good morning!!!! #95,462
Good morning. We are promised a few hours of dry weather today before thunderstorms come over. Should hopefully hold off long enough to get the sheep in and sort through the lambs.
Is any provision made to keep the liner from chafing on the edges of the rings or fasteners? Yes, it all looks well thought through.
The top edge is protected by covering it with mdpe pipe that has a slit along it's length. Another larger diameter capping fits over this once the liner is in.
Tank inner vertical edges and the rounded bolt heads are covered with thick adhesive tape.
A 3" radius sand/cement fillet goes around inside bottom edge.
David, good to see all the pipework finally in place. In years to come, when you glance at where the pipework emerges from the ground, you will still be smiling at the memories of your tunnelling adventures.
   / Good morning!!!! #95,463
Son said ZT quit on him and wont start. I said put some gas in it...... At least i hope that is all it is.
Yep, that was it..
I remember when my son said something happened to our B7100 Kubota.
Yep, it needed fuel. I bet he still remembers that to this day. Took more than filling fuel tank to get it running.
   / Good morning!!!! #95,464
69 this morning high of 85 under flood watch today and tonight only .12 in of rain others much more very humid summer is here. Be safe in the heat all and keep lathered up
Prayers for all
Prayers for Toppop
   / Good morning!!!! #95,465
Drinking first cup of coffee. 57° with partly cloudy skies this morning. Heading to 77 with some sun. Trip to Port Huron was nice. Cleaning lady this morning. Then cut lawn again. Cut lawn on Friday. It is over Sassy's heads again.
David, glad the gas lines got hooked up.
Mostly, good pictures.
Randy, hope recovery is going good. Prayers sent.
All other healing. Prayers sent.
Good Morning All.
   / Good morning!!!! #95,466
57F cloudy low 70's for high with more clouds.
Septic service call said no show today will be here tomorrow...dang.
Plans for today...trim dreaded ditch line and property lines darn ticks :( might mow front field if ground not to wet than see what happens the rest of the day.
Enjoy the day all.
   / Good morning!!!! #95,467
Yes, i only ran a diesel dry once. After having to bleed the injectors, you dont make that mistake again.
   / Good morning!!!! #95,468
Good morning! 70s to 90s today clear skies.
Ceiling project progress:
Get scaffold, check
That'a it, no more checks, but I did win the majority (3 of 5) of Hand and Foot cards last night and am heading to the brush cleanup with the FireWise group this morning.
Randy, where are you? You haven't posted for 6 days.
   / Good morning!!!! #95,469
70 going to 89, maybe storms again.
Mostly, please tell the story of that egg. Beautiful church.
BEF, get back in the house! Do you want to catch pneumonia? :)
Yesterday was quite a day. Started out by finding that the bears had finally come up the hill and broke a couple of our front yard bird feeders...got two of them together on game cam.
Mixed 50 gallons of gly and sprayed 5 of my food plots that were way overdue...was very hot with long pants and shirt on in the 90F sun. Been waiting for a time when it wasn't wet or windy...haven't had a day like that all spring, when I was at home.
Then belly crawled under the part of the house that doesn't have much headroom because of the duct work...looking for a leak in the cast iron drain in the old part of the house...plumber coming today. I really respect those guys...seems like it can be really challenging and sometimes nasty work.
Our internet went out early afternoon...at least it's a rarity.
Then the storm that was supposed to miss us shifted and we got 60mph winds and sideways rain...looked like the hurricane footage you see on TV...trees bent over sideways, chairs blowing away. In our front yard an 80+year old maple tree snapped in half about 10 feet up the trunk...so chain saw work today. Leaves and branches everywhere. Trees over the roads. Power was restored pretty quickly by our co-op, about 10pm.
2007 STERLING A9500 DAY CAB (A56129)
2007 STERLING...
2008 Ford Ambulance (A47477)
2008 Ford...
Miller Trailblazer 250G 4,000 Watt Welder/Generator Set (A55851)
Miller Trailblazer...
2013 John Deere 824K Wheel Loader (A55302)
2013 John Deere...
2023 BOBCAT T770 SKID STEER (A52706)
2023 BOBCAT T770...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
