sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 18,449
- Location
- Big Island, HI
- Tractor
- Bobcat CT4545 LS XR4140H (Mine) BX2380 (wife’s)
Awesome bounty, Drew
With the keyhole garden I can reach anything I grow in the garden. I put a thick layer of cardboard at the bottom to kill all the weeds. On top of that is a layer of anything organic like leaves, sticks, wood chips etc.. Then I put a thick layer of composted cow manure then 8" of top soil on top. The soil at the center will be near the top of the compost barrel at the center of the key hole and sloped down to about 3 inch below the edge. The compost barrel has lots of holes so the gray water from the compost will water my garden. The method of planting was introduced to Africa and is now very popular there since it maximize the use of water and allow for continual composting and building up the soil. Turning over of the soil is only needed once every 5 years to replenish the organic material at the bottom. A keyhole garden the size of mine can give me all the veggies a small family needs except in my case where my lady would probably want me to just plant a lot of hot hot hot pepper! What I usually do is to cut off the bottom of celery, green onions, etc.. and simply stick them in the dirt and soon I'll have more than my lady and I can eat. The last time I did key hole garden, I put 2 slices of heirloom tomatoes in the ground and had so many tomatoes soon afterward.
Not seen in the picture is the door on the compost barrel. I can open the door and shovel out the compost near the bottom if the barrel gets too full.
I just looked up the price for keyhole garden Whooa! This one is $509 and is way smaller than mine.
Cedar Keyhole Garden | RaisedBeds.com
66ーF and another 1.92 inches rain last 24 hours, 1.23 of it since midnight.
Jay, overview of how our water catchment works:
Rain from roof collected by gutters.
First part of collection fills the self draining 1st flush pipes.
Remaining water passes thru my 3 phase prefilter consisting of a course plaster core, a nylon filter, panty hose, then a second like prefilter on way to 4 foodgrade poly tanks, 4K gal each.
Pumped from tanks to pressure tank then filtered
100 micron
20-5 micron
5 micron carbon
1 micron
UV sterilizer light
Pretty clean by time it gets to House.
Prayers for all in need
Be safe
Have a great day
Thanks for the added details, David. Any idea how much flow through the tanks it takes to avoid stagnation probmems? I'm asking because I want to add storage up on the hill above my house, mainly for fire fighting, and I'm trying to decide if I want to plumb it into the home's water system or just run a pipe down from it to a hydrant and keep it separate. I don't use much water outside the watering season, which is June-October, and worry about 10,000 gallons sitting fairly stagnant durning the non-irrigation times. Not a big fan of using chlorine in the storage tanks, and even though they'll be light tight and I'll use a UV filter on anything I drink, I sure don't want anything growing in there...
How low is the rent? Are you talking about Government Assisted rent or private pay rent? I was always under the impression that it cost more to live in Hawaii.Many people live there due to affordability. Locals know and accept the risk. They live there at Pele’s grace. Their attitude is often minimized at the expense of the mainland welfare transplant here to take advantage of the low rent. One “poor” family even said they might be forced to return to Texas.
