Good morning!!!!
   / Good morning!!!! #41,881
duplicate
site seems to be having problems this morning. Super slow, duplicate posts and this error message constantly:
502 Bad Gateway
update, just worked fine. I got that 502 code four times.
   / Good morning!!!! #41,882
27 this morning high of 44 later today more snow cleaning and shoveling sidewalks. Work at a standstill until snow melts
   / Good morning!!!! #41,883
Good morning. Still way above freezing here, although the wind is going to be gusting above 45mph for the next few days, so doesn't feel quite as warm as the thermometer suggests.
Kev, with the sewing machine pedal, are you thinking of adjusting the current in the brake coil by connecting it in series, without a separate brake controller ? This could work, although only if the resistance just happened to be the right amount for the brake. Also it would need to have an adequate power rating, or else it would get too hot. A quick web search suggests a small single axle pair of brakes pulls in the region of 6A when on hard, the bigger 10"/12" drums a few more amps, so the brake coil is only going to be around 2 ohms or less. My guess is that unless it is an industrial sewing machine, it probably won't have the resistance range you need and could start smoking. Have you heard of someone who has tried this before ?
502 Bad Gateway
I am seeing the same, thought it was my poor internet connection until you posted that.
   / Good morning!!!! #41,884
Full moon light sky 12F low 30's for high.
Last week of January boy this month has slip by,but the day light getting longer tho. :)
Hope all doing well after weekend nasty storm.
Soon heading down to valley for 8.
Enjoy the day all.
   / Good morning!!!! #41,887
Got the 502 Bad Gateway, too.
I think it's Eric's fault, he left the gate open and his lambs got out!
Besides he got the error first...
and perhaps someone could explain:
HTTP Error 502 Bad gateway
Introduction
A server (not necessarily a Web server) is acting as a gateway or proxy to fulfil the request by the client (e.g. your Web browser or our CheckUpDown robot) to access the requested URL. This server received an invalid response from an upstream server it accessed to fulfil the request.
This usually does not mean that the upstream server is down (no response to the gateway/proxy), but rather that the upstream server and the gateway/proxy do not agree on the protocol for exchanging data. Given that Internet protocols are quite clear, it often means that one or both machines have been incorrectly or incompletely programmed.
   / Good morning!!!! #41,888
Coffee is done brewing. 49° with partly cloudy skies this morning. Heading to 64° with mostly sunny skies. Doctor apportionment for wife this morning. Then help neighbor with some downspouts that need to be removed and replaced.
Drew, got the 502 message couple of times. Hope to goes away. Several forums that I watch have been having problems last few days.
Good Morning All.
   / Good morning!!!! #41,889
Good Morning, 30 here with our high going all the way to 66. Have a have a Deep Massage/ PT appointment this morning, then some work this afternoon. Still working on end of the year bookkeeping/taxes at night. Not doing much, I wait till the end of the year to do all my business bookkeeping.
Eric, I actually was looking at a speed control pedal for wood tools Amazon.com: SE 975PS Foot Pedal Control Switch for Compatible Power Tools: Home Improvement and it says 1.5 amps but not ohms. No I do not know anyone else that has done this, that is why I am asking here. I was hoping this would replace the controller, otherwise I have no idea how to wire it up. I am a carpenter and really need help with this stuff, electric stuff not my forte. And now I have another question for you, with the raising of sheep that you do, does your wife work with any of the yarn crafts? Yes, I do know there I a lot of process between sheep and yarn, just curious.
RNG, LOL if I did a drawing, no one could read it.
   / Good morning!!!! #41,890
Don,
Post the make and model number of your pressure washer. I would be happy to do some sleuthing on your behalf. I really enjoy the challenge. :)
BE
nk1005mp
It's the auto start stop system
RNG - thats a good thought, Ill soak it!
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2014 Doosan DA30 (A52748)
2014 Doosan DA30...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
Gehl 2580 Round Baler (A50774)
Gehl 2580 Round...
2015 Ford F-250 Knapheide Service Truck (A51692)
2015 Ford F-250...
