Good morning!!!!
   / Good morning!!!! #25,081
58 going to 75, with a chance of showers.
Ron, I'm coming over for the free coffee.
Good advice, Drew. I'm using that approach on my 2001 4Runner (355,000 miles).
   / Good morning!!!! #25,082
Well today will be inside as rain and drizzle will keep me from working at least on outside. Plenty of paper work to do and bill to get together from last Friday. Several items need repairing starter on generator needs replacing for one, large concrete saw needs servicing walk behind needs air in tires. Oh my the Cowboys won last night in Jerrys world no less
   / Good morning!!!! #25,083
54F and partly cloudy @ 06:00 ... sunny with a high of 78F predicted for today ... then rain tomorrow morning between 07:00 and 10:00 then clear ... but with cooler temps.
Supposed to be nice for a couple days after that, then rain Thursday night and Friday, then a big cool down ... with highs only the upper 50's for a couple days ... then low 60's ...
Managed to remove the lead anchors for the vise stand out of the floor without destroying them ... then patched the holes with some patching cement that has been up in the shed for probably 35 years or more. Drilled four new holes and got the vise stand bolted down with the old anchors. New location will be much better ... much more light ... closer to electrical outlets and right next to the small welding table.
Spent the rest of the night grinding ... mostly bevels ... not my favorite activity.
Did manage to get three of the five upper jaw teeth tacked onto the pipe they will be welded to:
Pieces/parts ...
Not quite all of them tho ... have six pieces for the grapple - plus three more for another project (tree/shrub bucket) - that I need to cut out of the plate from the table ...
I'll lose 30" off the length of the table ... which is actually fine ... 4' x 5 1/2' should be plenty big enough for most things I'll be tackling, and it means more available space to work on a vehicle or equipment.
Well the coffee is done ... and I think I hear the angle grinder calling me ... :cool:
   / Good morning!!!! #25,084
53F now temps settling mid 70's for high.
Well its Monday again and we all know what that means..5 days before the weekend.
Got to pick small projects for after work since arrives before 7pm now. :(
Enjoy the day all.
   / Good morning!!!! #25,085
Free coffee today. 48ー with light fog this morning. Heading to 76ー with a mix of sun and clouds. Still a little to warm to start on fall projects. But I am ready with all the filters and oil. Chain Saw has a sharp chain. Chipper has sharp blades and full of gas. Tractor has grapple bucket on and full of fuel. Trac-Vac is fueled up. Time for fall to start. Looks like I will have to sit back and enjoy the great weather.
Very well done :thumbsup:
I am 2/10ths of an hour away from needing to do the 1600 hour service on the B2910 ... and no place close to having the other stuff serviced and ready to go for fall/winter ... :D
   / Good morning!!!! #25,086
56 and heading to the mid 70’s and mostly cloudy
we closed down our mountain place yesterday for the season, always a sad day
   / Good morning!!!! #25,087
Look on the bright side Spring is just around the corner
   / Good morning!!!! #25,088
Fired up Kubota yesterday as well as TR-6 after having sat for two months no worse for wear just wish weekends were longer. Kubota still has blade hooked up maybe it's trying to tell me something
   / Good morning!!!! #25,089
Good morning, 55F mand foggy here this morning with a high today of 75F. Going car shopping after work, our Intrepid is a 2001 and the body is starting to go. Will pass the car down to youngest son, just needs it to drive back and forth to work.
   / Good morning!!!! #25,090
Kyle,
this might be just like that old adage that advice not requested is often not appreciated.
but in for a penny...
I wouldn't worry about market value at that level; more concerned over total cost to make it a reliable runner.
I mean, what can you buy used for three grand anyway? Something else with high miles...
only you know what else has been replaced on it. If trans, shocks, muffler, cooling and front end have been rebuilt, maybe investing more in the engine is a good idea.
I ran into this a number of times when I did family financial planning. Usually one spouse wanted to get rid of a car when the other one
wanted to fix it up. Not having a car payment and paying cash for repairs so that you remain debt free is a real motivator.
One might always ask oneself, is it better to buy a used Toyota or Honda? If one is reinvesting in a daily runner for a longer commute that gets 20 mpg, then alternatively choosing a 40mpg diesel Cruze or VW Golf or any number of affordable hybrids for longer commutes would justify the cost in order to lower overall cost of operation.
but then of course you get down to the bottom line which has to include whether you like the car, whether you need a full size car,
or is it time to sell it for salvage. An eleven year old Impala ought to go 300K miles if maintained. Particularly a small block V8. Assuming the Impala had the V6 that was the Buick clone, it was supposed to be a very durable motor also. So if you rebuild them, they should last a long time.
Or donate it for a possible tax credit. I hope this helps somehow so you consider all the alternatives.
now back to regular programming.
Thanks Drew. Our thoughts run parallel. :) The rest of the car is good, but the tranny may need some new servo dealyboppers soon. It does have 293K miles. I had just rejuvenated the front end with new A arms, strut shocks, brakes, cv joints, bushings, etc. It rode like a new car until the weird noise in the engine.
2017 Ford F-250 Enclosed Knapheide KUV Service Truck (A50323)
2017 Ford F-250...
Unused 2025 CFG Industrial QNT50R Mini Excavator (A50322)
Unused 2025 CFG...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
2018 Land Rover Range Rover Supercharged 4WD SUV (A50324)
2018 Land Rover...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
