Good morning!!!!
   / Good morning!!!!
Going to Menards in a few minutes, I found they have the roofing panels I need in just the right length. No cutting needed. I am fixing a roof that was damaged by falling branches during this winter's storms. Haven't been to a Menards in several years, I am taking the wife, so I won't be able to walk around as much as I would otherwise. But I will probably spend lesss...:)
   / Good morning!!!! #22,102
54*F & developing fog. 65 tomorrow with clouds and chance of afternoon rain.
The minisplit install got off to a late start, the tech had a no hot water trouble call to go to first. The electrician came and did the wiring, the outside units are mounted on the walls, the inside units are on the walls with the piping through the wall. Tomorrow holes go up through the ceiling, piping through the attic, then it gets purged with nitrogen before filling with refrigerant. There is some minor plumbing to do for the condensate drain lines. So far, so good.
   / Good morning!!!! #22,103
2014-06-05,
46 right now and a high probably of rain. Today's high is supposed to be 68.
   / Good morning!!!! #22,104
2014-06-05, 0400
   / Good morning!!!! #22,105
69 and damp from the T-storms and rain last night.
Up and rolling so I can go to a classified Job Fair up in the beltway.
Have an awesome day folks.
Be well,
David
   / Good morning!!!! #22,106
54 degrees and heading to the mid 60痴 with showers coming in around noon time.
Good luck David with the job search!
   / Good morning!!!! #22,107
Need to pour second cup of coffee. 48° with clear skies this morning. Heading to 72° with sun all day. Off to see my Mom and celebrate her 95th birthday.
Good Morning All.
   / Good morning!!!! #22,108
69 and damp from the overnight showers.
Putting the sprayer on today - spraying a couple of food plots and attacking some poison ivy.
   / Good morning!!!! #22,109
54*F & cloudy.
Good luck at the job fair David. I hope it helps to see what's out there, and making some connections.
   / Good morning!!!! #22,110
Good morning all. 64F and partly cloudy going to mostly cloudy and 80F. Packing and leaving for Bike across Kansas today, ride starts tomorrow 550 miles with 800 of your closest friends :).
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
2014 INTERNATIONAL DF677 (A52472)
2014 INTERNATIONAL...
