Good morning!!!!
   / Good morning!!!! #18,561
Zero outside this AM. Cold is here to stay.
The issue now is black ice, last night the temp crashed right at sunset and the ER started getting the calls. This AM, I hear the firestattion in the distance responding.
Please be safe outside.
   / Good morning!!!! #18,562
Well it got down to zero last night, but not below. Can't hardly believe we missed the last snow storm and are having a heat wave compared to Tomas and Roy's temps! Roy I would bet you will maybe have to bleed that oil line to the furnace once they deliver that liquid gold!
   / Good morning!!!! #18,563
I was siting here reading Riptides post and looked at my thermostat and it hit -1 as I was watching...
I think in reality is is 1 or 2 outside though.
Yesterday shoveling snow off the gravel drive in 12 to 15 degrees was COLD...
Be well all.
David
   / Good morning!!!! #18,564
-17 C last night in real degrees that's 1.4F. Celsius makes it feel colder, somehow -17C sounds worse than 1.4F. Got the new shower valve in yesterday turned the water on, good news, none of my solder joints leaked and I didn't set fire to the house, bad news, the thing wouldn't shut off. After a few expletives, and the thought of having to explain that we wouldn't be using the bathtub in the morning, the brain clicked in and I removed the cartridge and reseated it, voila all is well. No explanations required domestic bliss continues. Shower works fine, just have to set the upper temperature stop, now that I figured out what all those extra parts were for. Should be able to build the access door to close up the hole in the closet and put everything back in order. Have a good one and stay warm. The forecast here is for some snow in the next day or so and a little warmer, high of -8C tomorrow.
   / Good morning!!!! #18,565
Got coffee pot brewing. 56° with partly cloudy skies. Heading to 73° with rain later in day when cold front moves down from the north. Need to put things away before the front moves in. Winds should be + 40 mph. Need to get warm cloths out for 1 day of cold. But no freezing temperatures.
Good Morning All.
   / Good morning!!!! #18,566
-1.5 this morning, the first official below zero reading since 1977! I can't stand much of this global warming!:laughing:
   / Good morning!!!! #18,567
-8 this morning with clear skies only getting up to 0 today. wind chills -15/25 below wind chills.
   / Good morning!!!!
In tight spots, I have taken to using Sharkbite fittings. They are similar to the push fittings used for air and hydraulics now in the shops. I've never had one leak. Lowes sells a cheaper one as a "gatorbite" I didn't like those as much.
   / Good morning!!!! #18,570
Good Morning. 1020, sunny, 41F with 47% humidity. Forecast high of 54F today and a low of 29F tonight. It stayed at 28F from 0630 to 0830, or at least that is what weather underground said. Not sure if their equipment was working right.
I'm off to Panama City. The Dr admitted Mamma to Bay Med yesterday and I need to run her a bag of stuff down there. I'm charging my tablet now, so I may log back on at the hospital. Everyone have a good day.
Larro
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
Case-IH 370 Steiger (A50120)
Case-IH 370...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
New Holland HM236 3pt Disc Mower (A50774)
New Holland HM236...
2010 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2010 Ford F-150...
