Good morning!!!!
   / Good morning!!!! #96,771
washed both Masseys and squirted off my truck. That's enough for today, now some quiet time.
Did find a little eye opener when lubing tractor after wash. This time made sure pin head was facing mostly forward and vertical.
We find that those nice easy to pull and adjust hair pin clips are just that easy for tall grass and hay to remove.
Many of ours have been replaced with a twist of wire or a doubled over welding rod they tend to stay better, don't look as nice :)
   / Good morning!!!! #96,772
Drinking first cup of coffee. 69ー with thunderstorms this morning. Heading to 81ー with cloudy skies. Betty got a good night's sleep and is feeling better. This weather has an effect on people that have breathing problems even inside in an Air Conditioned house with super air filters. Next problem. Oxygen Condenser loud and produces a lot of heat. Are they all like that? Need to put it in a room we do not use or wifes room if it does not got too hot in there when it is on.
Roy, don't whether to congratulate you with 4 women or send condolences. :D I am sure they will take extra care of you. :thumbsup:
Buckeye, hope the first treatment works. Prayers sent.
Looking, good to hear from you. Glad AC is working again. It's been hot even in northern Canada.
Prayers for all.
Good Morning All.
All that I have used are loud and Hot,we put mine in the laundry room and ran tubing to the bedroom which solved the noise and heat for us. There is always a but I guess, we have a 7 C.F. freezer in that room and the heat from the oxygen machine caused it to run constantly so the electric bill went way up. Another thing to consider, if she is on Medicare and they are providing the machine, they charged Medicare $500 per month for the machine. You can buy them all day long on Craig's list and own it outright.
Just a couple of things to be aware of.Obviously she needs the O2 so you have to do it but there are some work arounds.
   / Good morning!!!! #96,773
70°F and .32 inches rain.
Maybe something of an R & R day?
Hand and Foot later.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #96,774
Thanks. Have the problem solved for now. Put it in her bedroom. They are not sure she will need it long term yet. So keeping options open.
   / Good morning!!!! #96,775
One other thing Ron,if she is using medicare supplied canulas,the ones I was given were large, hard,tubing that made my head sore behind my ears.I found some on Amazon that were much smaller and softer plastic that were more comfortable. I hope she gets off it soon.
   / Good morning!!!! #96,776
Don, very impressive, I've never seen jars grown from seed before - were they from a bottle plant ? :)
They were from the Monsanto GMO variety. I know California can't get the seeds and I don't think your country allows the import of the seeds, too bad it saves a lot of time. It's called the PPPPPP plant (Peter pipper's perfect pickin pickle plant). Note: The jars need extra irrigation till they close up.
Humidity is in the 40s so it's a dry cool Texas hill country 90 something degrees kind of day. It's not at all like the high humidity shirt soaking steamy weather most of you are experiencing and its nowhere near the series of 112˚F of years past (not heat index number.)
Ron good to hear Betty is back home and only needed a bit more O2. Do you think the heat has anything to do with it?
Buckeye, hope your second round of treatments are easier than the first but more effective.
Laid back Sunday even the card group is not competitive on Sunday as it just has leisure play in the afternoon that does not go on your permanent record.
I need a short road trip this week to look for a compass rose. One that is flat, made of metal and can attache to my rock patio. My wife misses the other because it alway gave her a sense of direction. Besides I think Buckeye needs a beacon to locate me.
   / Good morning!!!! #96,777
Don. Instead of metal overlay, maybe consider cutting one into your concrete drive? Single width blade cut and use a contrasting grout.
   / Good morning!!!! #96,778
rlgustafson
Thomas .... Boo Boo may be scheming the Grand Breaking and Entering Plan!
I do believe your right now we got feel for each other....looking forward to challenge.
   / Good morning!!!! #96,779
87F 10 degrees colder than yesterday with steady breeze.
Got everything done I wanted,as I return from checking game cams Mrs. said outside sillcock won't shut...sure glad she scooted down stay turn off ball valve feed...try to get parts at Home Depot no luck tomorrow stop at FW Webbs see if the stock parts if not new sillcock I'll install...figure the odds for parts 40 years old now a days.
Dinner sure smells good so I better start shining up to the Mrs.
Setting on the deck with smooth cigar scotch with ice gonner happen around sunset.
Enjoy the evening all.
   / Good morning!!!! #96,780
Looks like I’ll be replacing all the wood with vinyl and painting doors and divider with automotive urethane single stage.
BEF, thinking about you buddy.
Met the new minister at church today, I was hobbling out when he comes running up behind me and gives me a big hug! He and I are new there and it was nice to talk with Rev Koo, he is Korean and reminds me of Dr Ken the comedian.
Walking a little stiff last couple of days but so much better than recent past.
Ron, glad you’re getting the O2 situation worked out for the Mrs. Prayers for all you folks.
SKID STEER ATTACHMENT MULCHER (A58216)
SKID STEER...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
Giyi 27" Mixing Bucket (A57149)
Giyi 27" Mixing...
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
1994 Landoll Detach Trailer (A57148)
1994 Landoll...
2019 FREIGHTLINER WATER TRUCK (A58214)
2019 FREIGHTLINER...
