Good morning!!!!
   / Good morning!!!! #111,921
RNG, glad you di not have too much trouble switching everything out. First time doing (on / off) it is somewhat daunting. Putting it back on the first time will be a challenge to line everything up, but after a couple of times, it is really easy.
Eric, sounds like you had an enjoyable day fishing. Just going through the motions is nice.... even if the fish are not cooperating! Sounds like the sheep needed a change of pace also. Glad they came back to their senses and returned to where they should be.
   / Good morning!!!! #111,922
If you go due north out of Lancaster you get to a wide place in the road called Neffsville. There is a Post Office, a beer distributor, a sports bar, A used car lot, 3 car repair places, one convenience store, a vet, A real estate office and the school campus. Listing it all makes it sound better than it is. Anyway we live just west of town.
Chris
   / Good morning!!!! #111,923
Good morning all 40 going up to 70 today and getting warmer finally. Usually last frost is mid-april, not mid-may.
Got the grass mowed behind the garage last night. Had a lot more branches on the ground since last visit back there a few weeks ago due to the high winds.
Lots of gnats chasing me around when the wind stops, so don;t mind the breeze so much.
Pool open in a week, that will make stay at home a lot nicer.
Hope all are well, stay safe.
   / Good morning!!!! #111,924
59°F and partly cloudy with some light drizzle this morning, going up to 82° today. Looks like we have a chance for a pop-up storm around noon, then more tonight after midnight. Potential for storms all the way through Sunday.
Wife has been thinking about replacing a couple of her sewing and embroidery machines with one really nice machine. Some that she was looking at are crazy expensive, more so than my new car. Not going that direction, but still looking. Last night after dinner, she surprised me by suggesting that she was instead reconsidering a previous idea of having a concrete floor poured in the barn. She found a guy about 40 miles east of us and got a quote at $5500 for 5" of gravel bed and 6" of concrete and rebar for the 29' x 24' interior area. He also said it could be cheaper if he went 5" and wire instead. I told her to keep shopping, or maybe just get the new sewing machine and we'll look at doing the barn floor again next year, as planned.
Great news about Ellen, Randy.
   / Good morning!!!! #111,925
The driveway here cost about $10/sq. ft., so that quote is pretty good, Paul. Big part of that was for transport; I'm a good half hour from the closest concrete plant.
   / Good morning!!!! #111,926
Good Morning!!!! 54F @ 5:15AM. A mix of clouds and sun during the morning will give way to cloudy skies this afternoon. High 71F. Winds SSE at 10 to 20 mph.
How well does the EvapoRust work in the ultrasound, Rick? I've had problems with other cleaning agents depositing what looked like a copper plating, or with discoloration of aluminum parts.
Last couple of flats on the old tractor I had to resort to starting fluid to get the beads to seat. Man, I really hate doin' that...:grumpy:
Hope you don't get stuck, Don.
Weed eating and shoveling after an outpatient procedure? Randy, you hit the jackpot with Ellen!:laughing:
There's not much modulation in the foot pedal that controls the thumb; it's more or less all on or all off. Maybe some lubrication in the pivot would help?
Took my time dismounting the backhoe yesterday, not being exactly clear in the beginning about what would move where. Two large steel pins hold the hoe in place, and as expected, neither one wanted to come out. They work like the ones that hold the loader on the old Kubota, with captured cross pins at one end that drop into a hole in an adjacent plate to keep the pin in place. Ended up using a short section of pipe on the cross pins to get the big pins turning, and was able to work them free. And as expected, both were dry as a bone and rusty. Once the hoe was off the tractor and on the ground, the hydraulic lines decoupled easily, losing only a tablespoon or so of fluid all told, and there was no need for a chair under the hoe to hold it up. The best part is the tractor is a whole lot more stable without all that high weight on it. And next time, it'll go a lot smoother.
Took my time putting the three point hardware on, too. The directions were pretty clear this time, even to specifying torque values for each of the bolts. Had more rust to deal with in the bores holding the pins that the front of the 3PH arms pivot on, and in the threaded holes the bolts engaged. Used a tap to clean up some of them, but I didn't have a 12mm tap for the biggest ones and used a copper bore brush in the drill for those, and lots of anti-sieze on the threads. All the pins and bores got generous doses of spray on lithium grease as well.
View attachment 655454 View attachment 655453
Most of the assembly I did was a one-time only thing, and won't have to be repeated next time I want to use the backhoe. And I won't have to crawl under the tractor to bolt anything on, either, as is the case with the old tractor. I have yet to add the top'n'tilt cylinders, as the valves to control them won't ship until the end of the month, so the verdict is still out on how difficult the mount/dismount procedure will be.
I was half thinkin' I'd have to purchase a larger box blade, but the old one is as wide as the rear tires and will be fine, at least for now. I will have to alter the mount for the receiver hitch that rides above the top link connection though. The new Class 1-2 top link eye is so large it won't fit under the mount. I'll need to check the eye on the hydraulic top link to make sure it's not even larger.
After lunch I ran into some measurement errors on the solar panel rack braces; I guess that's why they make welders, right? But the tractor had no problems at all with the steep hillside or moving two 16' lengths of pipe at a time. I was a little worried about slipping on the gravel, but once I remembered to engage 4WD, it was a non-issue. And it was nice being able to use the box blade as a sort of land anchor to back up the parking brake.
The propane man is due here at 8AM to hook up the generator, and so far, he's always been early. And not just a few minutes early, we're talking a half hour early last time, and it cost me a breakfast.:irked: So this morning I'm allowing plenty of time for morning chores, and will have the gate open early, too.
Hang in there, gang, Friday's comin'!
“How well does the EvapoRust work in the ultrasound, Rick? I've had problems with other cleaning agents depositing what looked like a copper plating, or with discoloration of aluminum parts.”
I’ve had good results using EvapoRust on ferrous materials RNG. Generally I use either EvapoRust or Simple Green HD Pro in my ultrasonic cleaner. I never use EvapoRust on Aluminum though. The simple green is for great / oily parts cleaning.
My ultrasonic cleaner has a 6 liter capacity so I can get pretty large parts into it. It also has a settable heater which I think makes a big difference.
When I clean parts with the EvapoRust, I rinse them well with water, then set them in the sun to dry. No sun? I put them on an old baking tray and into the oven, in the quarters at the shop, set oven on warm. I try to get some primer on them while still warm.
   / Good morning!!!! #111,927
Good afternoon. Things are running a little late today - most of the sheep were missing when I went round the fields this morning. Found them in the far hay field. Some looked guilty and came out no trouble, while others were more reluctant. I have had trouble before with the odd footpath walker deciding to go through a gate that is a short way from the path, instead of over the style, then not fastening the gate properly. I have now wrapped 5' of chain around it, so hopefully that should keep both animals and humans in the right place.
Fishing was slow yesterday, very bright and no wind. Caught only one fish, though really enjoyed sitting in the shade and watching the swallows skim the water.
Thomas pleased you finally got your first drop of firewood. Are you pressed for time to get it dried to use later this year, or do you already have some for next winter?
Rick, who would have thought that you could get so many hours of fun out of repairing wheeled steps :) :thumbsup:
“Rick, who would have thought that you could get so many hours of fun out of repairing wheeled steps “
I’m easily entertained Eric. This thing was almost free so ... cheap entertainment .. as well.
   / Good morning!!!! #111,928
Guy I know scored a bunch of those ladders being thrown out. He donated one to our church, gave his dad one, and sold some.
My BH has one pin very difficult to remove. There is no one spot where all the tension is off. It appears the hole doesn’t properly align. I have to beat it out with a sledge, and not much room to swing. I grease it good.
Last time I took loader off I greased pins good. They were bone dry, but pins pulled right out.
Lancaster is pretty area. We go up there just to eat sometimes.
   / Good morning!!!! #111,929
A clear and sunny 30ºF for today’s low temperature; a mostly clear and sunny 57ºF presently; and I anticipate a mostly sunny afternoon with high temperature in the low 60ºF’s. The NWS issued a Fire Risk today due to increasing wind and decreasing dew points and it looks like tomorrow I’ll be seeing some decent T-Storm activity in the PM. Just when the soil is starting to dry out I’ll be seeing more rain into the weekend and again early next week. :( I better do something productive outside today and take advantage of this beautiful weather.
Randy- I am happy to read that Ellen’s surgery was timely. :cool:
Eric- I am happy to read that your day fishing resulted in a caught fish.
I hope that everyone is having a decent day.
My + thoughts, wishes, and prayers.
   / Good morning!!!! #111,930
Bird, when I was initially asking my ortho doc about the longevity of knee replacements, he told me about 10-15 years.... that was why he was procrastinating doing mine unless absolutely necessary. He said if I was still really active, I would wear out faster. I thought they would surely last a lifetime
Yep, I'd read some things about them lasting 8 to 10 years, but maybe enough improvements have been made to change that; at least my doctor says so. I've posted, many years ago, about the experience I had. It looked like a terrible bruised leg for awhile and the physical therapy afterwards wasn't a lot of fun, but the surgery and my time in the hospital were almost painless, and I was just amazed at the fine treatment I got in the hospital; just never saw anything in any hospital that good.
   / Good morning!!!! #111,931
55F, overcast and raining @ 11:00.
Finally have some more seasonable temps in the extended forecast, unfortunately they're accompanied with numerous opportunities for precipitation ... :(
Finally got 4th birdhouse painted yesterday ... after doing some "tech support" ... :laughing:
Will get the roof on that one oiled up today ... along with a variety of other tasks.
Making some progress on getting all the empty ALU cans crushed ... :thumbsup:
Needless to say: inside day today ...
Hope everyone is staying safe ... and enjoying their day ... ;)
   / Good morning!!!! #111,932
Boy! Nice day today...think I'll leave work early (if the boss is OK with it) and mow my lawn!
   / Good morning!!!! #111,933
67°F and 0.0 rain.
Need to cut dog’s area with push mower and in front of pool with Craftsman rider and I think all mowing will be caught up for a few days.
Prayers for all
Be safe
Have a great day
   / Good morning!!!! #111,934
67°F and 0.0 rain.
Prayers for all
Be safe
Have a great day
Sounds like me...caught up for a few days...and here I am... about to go see how wet the grass is. :)
   / Good morning!!!! #111,935
Tomorrow is looking interesting weather-wise for quite a few of us. It's looking ever more likely that I will be seeing some decent to serious T-storms tomorrow. I do not want nor need any more rain at the moment. My wet areas are still saturated.
   / Good morning!!!! #111,936
Good afternoon! After some rain this morning, turning out to be a decent afternoon. 68 now.
With the rather cold spring and house arrest orders, my bikes are getting neglected. But yesterday was really nice, I really needed a break from some of the work crap, so took my entire lunch to just ride. I even took pics!
Everyone stay safe out there
   / Good morning!!!! #111,937
Maybe one more....the short way home is across these fields
   / Good morning!!!! #111,938
Don, when I saw eye's in photo I started having regrets about posting photo. But it is what natures does. $50 visit seems high. You still using the one in College Station. Or was it in Bryan. :confused3: They treated me good.
No, he is too far away - about 2.5 hours one way. He was good.
This dentist sent out another e-mail saying that they made a mistake and the sanitization fee will be only $20 instead of $50. Ha, I bet people were canceling like crazy and they were forced to be reasonable. I'm still going to try a different dentist. He was kind of expensive last time anyway.
No mud in the park and more people are showing up to work, fun day. The park was mulching but still couldn't catch up with us and we left them with 6 big piles.
   / Good morning!!!! #111,940
Guessing you really enjoyed that lunch 🤙
Nice pics
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
iDrive TDS-2010H...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
2017 CATERPILLAR 289D SKID STEER (A60429)
2017 CATERPILLAR...
1996 Dorsey Enclosed Trailer, VIN # 1DTV11520TA252324 (A57453)
1996 Dorsey...
